Hot Rods Will the Girlfriend Care if I Cheat??
Discussion in 'The Hokey Ass Message Board' started by cruzr, Feb 19, 2010.
  1. Godspeed
    Godspeed
    Well here is one that is using some inexpensive parts that a teenager could have afforded, putting it into an application that it was never meant to be in, trying to get some more HP out of it so I can go down to the drag races and have a good time. I guess I don't know what hot rodding is about (cheesy?).
    That said, I have a 2x2 Carter BBD that are mounted frontwards and backwards (look at the picture). I use a home made progressive linkage (no mail order kit available). Carb's I bout for $10/each (no lie). Rebulid kits were $14/carb. I bought all of the linkage pieces at the local hardware store (shaft collars, 1/4-20 bolts, bronze sleve bushings). The most expensive part was the Vintage Speed adapter drilloed inboard for the Carter 4bbl (no extra holes for the spread bore set up). A used Eldelbrock manifold for $60. The entire set up with gaskets is less than $200. The BBD's flow 280 CFM a piece, giving a 560 CFM total (just right for my MoPar 318).
    Notice I have no "I gotta have's to be real" Strombergs, SBC, genie triple duece intake, all made before 1959. I did not use any aftermarket kits, instead I bought a retro Carter manual and figured out how to convert the BBD's to 2x2 myself. The only "six pack" Holley set up for a small block MoPar is $1800+, and I am not in that price league. It probably would have been cheaper and easier to do a newer 4 bbl and rebuild it, but honestly I like the vintage look (oh, I forgot that others here think the homeade stuff is cheesy rat rod).
    For me, as long as your are putting God and familly first, then have a little fun with your hot rod. High dollar perfect retro, or not.
    (P.S. If there is anyone interested in this set-up, PM me)
  2. Rickybop
    Rickybop
    Kinda like your way of thinkin' and doing things, Godspeed. - Rick
  3. Grumpy
    Grumpy
    from NE Ohio
    Make your own...
    My buddy milled the 4bbl riser off a old aluminum intake, made a new piece of aluminum for his 2x2's, and welded it together.
    Works like it was factory.....
    Only took him about a week to build:rolleyes:
    :D
  4. Godspeed
    Godspeed
    Very nice Grumpy!
    Oh if I only had your talent in a machine shop!
  5. Grumpy
    Grumpy
    from NE Ohio
    Oh, I cant take credit for it. It belongs to one of my buddy's. He built it, owns it.
    Thats him and his green flaked T in the pic.
  6. cruzr
    cruzr
    ok........thanks for the input, after reading everything and also knowing whats really right for the car,ive decided to have ****ster27 build me a 3x2's seup.I spoke with him on the phone and feel he's the right guy!
  7. hrm2k
    hrm2k
    good move cruzr ! **** is a straight up guy and does really nice work. You won't be sorry for your decision.
  8. nutajunka
    nutajunka
  9. greaseguns
    greaseguns
    dont see what the fuss is both vintage speed and ****s set up WTF look the same
  10. cruzr
    cruzr
    no.......i said **** is making up a traditional 3x2 setup for me, or at least thats what i meant........
    anyway i think i will be happy
