Projects Will this leave sand scratches?
Discussion in 'The Hokey Ass Message Board' started by flamedabone, Sep 10, 2018.
  1. flamedabone
    flamedabone
    DD1D9BD7-3269-4A3D-BFA6-93BC355904BC.jpeg I blocked my primer to 320 and want to make sure I don’t get sand scratches on the top coat which is semi gloss black urethane. Will this be fine enough??
    Thanks -Abone.
  2. What grit equivalent is it?
    I generally stop at 400 on single stage but will finish with 500 for black
  3. flamedabone
    flamedabone
    That is the unknown part, what grit is “superfine”?
    -Abone.
  4. 19Fordy
    19Fordy
    Sand primer with 400 grit prior to painting.
    Some folks let the body work sit for a week or two after priming to avoid shrinkage
    problems later on.
  5. KJSR
    KJSR
    from Utah
  6. john worden
    john worden
    from iowa
    I'd bet "superfine" is finer than 320
    Don't use products without knowing exactly what they are. Costly mistakes can result. That sounds like a home improvement store product.
    I suggest 400 followed with sealer.
  7. flamedabone
    flamedabone
    Ah Ha!! 500-600 grit was the number I was looking for, not sure why I wasn't smart enough to find it.
    Thanks, -Abone.
  8. hrm2k
    hrm2k
    I did the edges of the engine cover of my V8Corvair. I sanded them with a red 3M scrubby pad...…….pretty co****. I used duplicolor trunk paint on the edges. You can't see any scratches in the paint
    Just Gary likes this.
  9. 57 Fargo
    57 Fargo
    Nope, definitely a body shop product, quite handy actually
    X38 likes this.
  10. RMR&C
    RMR&C
    from NW Montana
    Those sponges are great for sanding louvers and fine details!
    57 Fargo likes this.
