Hot Rods Will this motor mount survive?
Discussion in 'The Hokey Ass Message Board' started by Gordon Reed, Feb 23, 2021.
  1. If we can see the whole damn car we might be able to tell you where are you going wrong.
    Something here is either very obscure particular to your build And you’ve managed to do some thing nobody else has thought of,, Or you’ve got something wrong
    j hansen likes this.
  2. That motor mount as is will not survive.
    Okie Pete, Special Ed and alanp561 like this.
  3. krylon32
    krylon32
    from Nebraska
    Done a few ch***is over the years and I am always amazed at what people come up with to mount a motor. If you need it that high build some boxed steel legs on which you mount the Ford motor mount biscuit. I agree, your current design will probably not survive?
  4. Mr48chev
    pinion_angle_transmission_anle.png One simple question: Why the hell are you trying to jack the engine up in the air way too ******** high, rather than correct the pinion angle to what it should be? That doesn't make a lick of sense.
    It seems way simpler and far better in the long run to place the engine where it belongs and correct the pinion angle to what it actually should be.
    That said, the only thing I have seen with that steep of a pinion angle is a seriously lifted 4x4. Possibly some misguided 4x4 influence involved in installing the rear axle?
    mad mikey and alanp561 like this.
  5. Doublepumper
    Doublepumper
    from OR-WA, USA
    See post #20 for the correct method.
    alanp561 likes this.
  6. alanp561
    alanp561
    You have " about 5 degrees " or you have 5 degrees:confused:. Which is it?
  7. trollst
    trollst
    What I'm gonna point out....I see no welding on the frame, why not make a proper mount of steel, regardless of where these guys want you to put it. I personally mount engines so the fan is centered in the rad, so if your gonna mount it that high, then at least make a proper mount. Junk isn't permitted here, neither are disguised rat rods.
    Special Ed likes this.
  8. 1971BB427
    1971BB427
    from Oregon
    I'm just the opposite. I like motors as deep in the ch***is as possible. They do create one issue; the radiator/fan alignment. But I always figure a way around that. I hate having a huge trans tunnel, and tall driveline tunnel inside, so the deeper it sits, the less tunnel needed
    This is the floor in my '39 Chev coupe. A small driveline tunnel, and flat floors up front:
    -Brent- and Budget36 like this.
  9. squirrel
    and I like figuring out where the original engine center line was, and putting the new one right about there. It seems to work out pretty well, this way.
  10. Gordon Reed
    Gordon Reed
    YEAH! his motor mounts look pretty big as well. is it bad that they are that high? i’m building a street rod and like the look of having my tunnel ram way up close to the same height as the front window. but i heard about bad weight distribution?
  11. Gordon Reed
    Gordon Reed
    yeah i definitely like that fuel altered look as well it just was funny that the pinion angle was off too. it helped me push in the direction of having my engine higher and a bit more radical looking. i appreciate you trying to understand where a 19 year old building a car from coming up on 100 years ago, my mind is all over with ideas and inspiration. i have a lot of life left to build cars with way lower engine mounts and perfectly set pinion angles. right now it’s all about learning the ropes and if i mess up right now then next time i change it, or i wait till something breaks lol. thanks for the response
    Mat Thrasher likes this.
  12. tb33anda3rd
    tb33anda3rd
    you can do it. it would be good to have a proper rubber mounts. you will have a very large tunnel and foot room will be tight. not my style...
  13. patterg2003
    patterg2003
    Here is the ****er information on setting up drive line and the recommended angles. It is well illustrated. The ****er information shows what many are recommending. Lowering the engine closer to the ground will lower the center of gravity for better handling.
  14. Mr48chev
    The point is, that while your engine looks like it is setting up pretty high the pan rail is only a half inch or so above the top of the frame rail and Center line of the crank is barely above the frame rail. You engine just looks like it sits high from the sides Because the crank case is so tall in comparison to a lot of engines and maybe you could go a tad lower before the pan gets too close to the ground and maybe you can't. His centerline for his crank is a good six inches higher than yours. Meaning the bottom of that Chevy pan is right close to the top of the frame rail. That sir is what we are fussing about., The man has a rear axle that wasn't set in the ch***is right an is attempting to compensate for it by raising the engine. If he were shooting for a fuel altered look he probably wouldn't even be posting until it was drivable.
  15. Ziggster
    Ziggster
    I kinda had the same issue when I started looking into laying out my build. I’m much older than the OP but have no previous experience with hot rods in general. For me, and I’m guessing the same for the OP, the goal was to keep the frame as low as possible to the ground. While researching traditional hot rods, I quickly learned the motor mounts for my engine (Ford flathead V8) were going to be much higher than traditional rods which were essentially flush with the top of the frame rail. In my case, I think it will be about 3” higher than the top of the frame rail. Still haven’t figured out the details yet. In the case of the OP I’m not really sure what a poly tube with steel core is, but when building structures that support heavy loads, using structures built at angles with gussets is always a good start like what @Mat Thrasher had done.
  16. 56sedandelivery
    56sedandelivery
    There's a thread on here, "Street 'n Strip W powered T Coupe", by Collin Benoit. Page 4 has images of virtually the same mounts, only used with a saddle mount. Might look at that thread and maybe even contact the guy. I am Butch/56sedandelivery.
  17. zz29
    zz29
    Great video
  18. Collin Benoit
    Collin Benoit
    Hey guys. I’ve got a somewhat similar setup.
    Loosely based off this
  19. squirrel
    that old picture shows a really strong motor mount. Neat, thanks for sharing.
    Collin Benoit likes this.
  20. gene-koning
    gene-koning
    The OP motor mount looks like its mostly rubber to gain the height, and the rubber won't last very long before it splits under the load.
    If the motor needs to sit that height, then most of the mount needs to be make out of steel in such a way it won't flex. When mounting a motor with mounts like those pictured, having a rubber bushing more than an inch high is pushing the limits of rubber products available these days, and then that one inch thick rubber better have a steel sleeve keeping the distance correct.
    As far as correcting the pinion angle, that is best to be done at the rear axle. Depending on how the rear suspension is set up, there are several ways to adjust the pinion angle that work well with different suspensions systems. Gene
  21. Collin Benoit
    Collin Benoit
    I guess I should have looked closer at the OPs photo. Didn’t realize that was all rubber!
  22. trevorsworth
    trevorsworth
    Oh Jesus. I looked at this thread a month ago and that never clicked.
