Hot Rods Will this rear end setup work?
Discussion in 'The Hokey Ass Message Board' started by plym49, Aug 5, 2009.
  1. plym49
    plym49
    from Earth
    Hi All -
    Will this rear end setup work? The stance seems OK but not sure if the articulation is correct.
  2. you've got your big and littles backwards....
  3. plym49
    plym49
    from Earth
    Day-umm
  4. AstroZombie
    AstroZombie
    from Marina, CA
    You need some fake rust added to disguise the wood..... Unless youre building a chevy!
    Whats the real reason you have the rear end removed though??!!
  5. striper
    striper
    No panhard bar?
  6. hotrod40coupe
    hotrod40coupe
    How do you get power to the rear wheels.:confused:
  7. Wildfire
    Wildfire
    With a nailhead, I'd double up the 2x4's and use screws and liquid nail.
    So did you break the last one or what?
  8. plym49
    plym49
    from Earth
    Broke an axle, while the banjo is apart I am switching to 3.54 gears, no time to work on the darn thing, and I had to move the car.
  9. E Burfield
    E Burfield
    It's going to stop like ****!
  10. sawzall
    sawzall
    building code calls for 4x4's
  11. Ghost28
    Ghost28
    Yep the first good bump and grandma is gonna be picking splinters. And knock off the chevy wood comments :)...John
  12. plym49
    plym49
    from Earth
    Hey, those nylon straps provide plenty of flex!
  13. Ed ke6bnl
    Ed ke6bnl
    no he needs a panhardwood bar ED
  14. plym49
    plym49
    from Earth
    Nah, we old timers been runnin' them this way for years......................
  15. plym49
    plym49
    from Earth
    LOL the fronts do all the work anyways.
  16. plym49
    plym49
    from Earth
    There's an envelope over there on the workbench with some cash in it - maybe you could look the other way?
  17. plym49
    plym49
    from Earth
    Screw and glue with a nailhead? Sounds wrong. Nail a nailhead! :)
    I broke an axle, bought NOS replacement parts, and am also switching ratios. Bad case of no time, though, and I had to move her.
  18. RAY With
    RAY With
    Your set up will work only after you change out the black retainer strap to Red to match the other side and equal out the load.
  19. plym49
    plym49
    from Earth
    I was so conflicted with those straps - the black one screamed 'rat', and the red one 'cliche'.
  20. 49ratfink
    49ratfink
    I've seen worse than that in Ol Skool Rodz
  21. plym49
    plym49
    from Earth
    LOL it would just be a lot lower
  22. Originally Posted by RAY With [​IMG]
    yeah , remember Red is positive and Black is negative, need all the positive forces you can get there
  23. rcoffey
    rcoffey
    :DHey at least the wheels arent from a s 10 and painted red
  24. Kerry
    Kerry
    Lookout for termites!
  25. dieselc
    dieselc
    from ohio
    damn its front wheel drive rat rod look out ol skool rodz, comin to do a feature.
  26. Royalshifter
    Royalshifter
    Moderator
    Looks like a Great dane getting screwed by a poodle!!
  27. I SMELL SMOKE
    I SMELL SMOKE
    no spring? its going to ride like a wheelbarrow.
  28. plym49
    plym49
    from Earth
    Damn, is it positive or negative ground?
  29. plym49
    plym49
    from Earth
    Now that's funny!!!! :)
  30. hasty
    hasty
    Now it is half timbered, will you call it a tudor?
