Will v8 fit in model t?
Discussion in 'The Hokey Ass Message Board' started by A-skool, Mar 24, 2009.
  1. A-skool
    A-skool
    I've got an opportunity to buy a full fendered '23 T with hood and sides. I've got a rebuilt '39 top loader I'd like to use. If I buy the car I'd like to run it with the hood, sides and full fenders. I know it will be tight (if even possible), but will a V8 flathead fit? Iv'e got a 40 Flathead and banjo I'd like to use. I also have a 265 chevy block. I'd rather stay with Ford in Ford. If it will clear the sides-what about firewall clearance and overall length, height, etc. I know it's probably been done before. Some here have probably done it. I also thought about built up A-banger, but what about adapter to 39 ******? Any thoughts would be much appreciated. Thanks...
  2. burger
    burger
    The "First 12 Issues" reprint from Hop Up has a feature on a fairly stock looking T-V8 built in '51-ish.
  3. That's my plan for the summer. 32 drivetrain into 23-25 T frame, undecided about body- I'd like a full roadster but a modified too... we'll see! ;)
    It can be done.
    JK
  4. Von Dago
    Von Dago
    from New Jersey
  5. Shaggy
    Shaggy
    from Sultan, WA
    I'd really plan on boxing the frame, but then again i abuse my tin
  6. Abomination
    Abomination
  7. spooler41
    spooler41
    A-skool, take a close look at the s/b Ford(221-302), I remember in the 70's they were a popular motor to use in restorod Mod.T's, with closed hood sides . There were quite a few covered in the magazines of the day.
    Good luck with your project. ..........Jack
  8. hotroddon
    hotroddon
    Have seen quite a few over the years with hood sides and a small block Ford
  9. Nobodys Hero
    Nobodys Hero
    from New Jersey
  10. stolen from another thread here on the HAMB , John Buterra's full fenders and hooded T sedan with a small block ford. as you can see it's a tight fit. with a sbc i think you will run into problems with the exhaust manifolds hitting the hood.....you would have to do some measuring to be sure. keep in mind this is a `26-`27 sedan....maybe a `23 is narrower? something you should check
  11. modelttom
    modelttom
    I'd put a Nailhead in it
  12. RodStRace
    RodStRace
    Oh, that's crea---Dreamy!
  13. Irish Dan
    Irish Dan
    I've seen many small block chevys in T's. It'll work.
  14. TERPU
    TERPU
    That is the baddest Modet T Sedan ever built! Thank you for posting it.
    Tim
  15. Like, wow DRuss... wow. Me likey. ;)
    Thanks for posting that.
    JK
  16. SUHRsc
    SUHRsc
    The 2 closed cars posted are a bit bigger then a 23.
    '23 is the smaller hood still, '24.5? i believe went to the taller cowl and then 26 got a good bit larger.
    Just something to keep in mind.
    Zach
  17. pasadenahotrod
    pasadenahotrod
    from Texas
    "MAYBE the 23-25 T (hood/firewall) is narrower than the 26-27"?
    MAYBE? Please note the top of the cowl is much higher than the 23-25 and the firewall is wider and taller.
    MAYBE?
  18. Another vote for the V8-60. There's a guy around East Tenn. somewhere with the *****inest little green T Model coupe (1925 I think), full fenders, hood top, (sides would fit but why hide something that perfect) with a hopped up 60 in it. Looks like it grew there and sounds oh so sweet. I know you're trying to use what you have and that's great but, if I were trying to do what you're trying to do I'd atleast look fo a 60 first.
  19. hey , pasadena.....know one (including me) didn't know for sure , i have never measured any T's or messed with any. i had an impression that they were smaller from what i have seen. just a suggestion for A-skool to check into before money was exchanged and motors picked out
    i'm glad you were here to straighten us out
  20. A-skool
    A-skool
    Thanks for all the replys. Pics were great. This 23 T is a "tall radiator" model. Maybe a little more height, but I think it is small than the later T's. I like the V60 a lot. I'm wondering about $$ and speed parts availability. I've looked around on the Hamb and found a few pics and threads of guys who have connected a V60 to a full size 39 top loader. I'm interested to know how that worked. Still planning on buying the 23T this weekend. Will post pics when I get her to the shop.
    Keep the ideas coming.
    A-skool
