Hi all from sunny spain, New to here, saw a thread from 2010 about repairing cracks in willys jeep blocks but have not seen anything about the problem with this one.I have been asked to help a freind who has a willys which the block has a crack between the cylinder bore and the exhaust valve port,-my question is -has anyone else had/seen this problem and if so what sort of repair worked.can it be Just welded and resurfaced and rebored?thanks for any help
Do you have any repair shops that deal with machinery repairs? My thought is an industrial machine shop would have experience dealing with cast iron repairs. Ray
Usually the crack is welded or s***ched and a new seat installed along with a cylinder sleeve. Depends on the severity of the crack. Iron s***ch is a common cold repair.
I have had several Willys over the years, but have never had to do any major engine work in the area you describe. A really good place to look would be www.ewillys.com Good luck
Go on the Willys CJ2A web sites, lots of good blocks and some decent running engines show up there. Don't know which block you have be sure to specify gear or chain drive cam.
