Hot Rods Wilson & Woods
Discussion in 'The Hokey Ass Message Board' started by Moonshine Dragster, Aug 10, 2018.
  1. I have purchased a new set of heads from H&H having trouble finding a spark plug to fit the depth and seat. 1. Heads have no taper. 2. Heads are machined for a 5/8" socket only ( 13/16" won't fit)
    that leaves out many plugs. Thread is 14 mm The Champion plug rc12yc and the Autolite 39 series are 3/4" reach and that extends into the chamber (way to long) so they are out.
    The Autolite AR133 racing plug has a tapered seat, we all know that you must not use a tapered seat plug on a flat surface the heat transfer will not work. So what plug are you using with your Wilson and Woods Heads?
  2. Jalopy Joker
    Jalopy Joker
    have you talked to H&H about this problem?
    lurker mick and whiteknuckle like this.
  3. PoTaToTrUcK
    PoTaToTrUcK
    I am running Motorcraft AL7C in my Wilson Woods (set #11) I have put 3,500 miles on this year with zero issues. DSCN9711.JPG
    Shorty Spark Plug: No
    Resistor: No
    Electrode Tip Material: Nickel alloy
    Electrode Core Material: Nickel alloy
    Insulator Type: Non-projected
    Spark Plug Thread Size: 14mm
    Spark Plug Reach: 0.437 in.
  4. KJSR
    KJSR
    from Utah
    No kidding. those guys have their **** together
  5. Hey Thanks for the info They really are great looking heads for a flattie, I'm having a tapered seat machined into this set for drag racing along with machining the valve area for my high lift cam so the my plugs will finish flush with the inside and the taper will dissipate the heat, can't wait to get them to the track!
