winding noise when I accelerate
Discussion in 'The Hokey Ass Message Board' started by sobpunx, Dec 13, 2010.
  1. sobpunx
    sobpunx
    I will try that, thanks
    I will disconnect the stereo but I don't think that's it but at this point it I will try any thing
    thanks again to all of you guys!
  2. shainerman
    shainerman
    I think you need to first try to identify where the whine is coming from. Ive had over 10 vehicles with 302s and ive had a lot of whines, haha. My daily is a 302 and an aod and the ****** whines like something fierce, I can definitely tell its in the ******. Tell me where its coming from, then I can try to help. Vacuum leaks can make VERY strange whines if its from the front. If its in the ******, same as everyone else said, just drive it and try not to think about it.
  3. pastlane
    pastlane
    Had a similar deal in my o/t daily. Turned out to be the front bearing in the alternator. Load didn't effect it, was strictly rpm related. Drove me crazy until I finally found it the hard way.
  4. sobpunx
    sobpunx
    Well its not the spedo cable or stereo.
    I'm still trying to pinpoint exactly where the sound is coming from but it doesn't seem to make it unless I'm moving with my foot on the gas, when I take my foot off of the gas it goes away, it sounds like a winding up noise.... this is really frustrating
  5. El KaMiNo KiD
    El KaMiNo KiD
    x3 on the trans pump..
  6. flthd
    flthd
    Ive had a dana about ready to grenade but it made an obnoxuis howling noise at certain speed,its a very distinct noise.Ha I hope thats some help.power steering?
  7. Deuces
    Deuces
    How about the vacuum line from the intake to the trans??? Those get brittle and pop leaks...
  8. sobpunx
    sobpunx
    I will look into the trans pump, as for vacuum line they are only about a year old but I'll double check them, they looked ok but I will look closer.
  9. blackrat40
    blackrat40
    Unfortunately it sounds like it may be the transmission.
    Did this just start suddenly or has it been there and getting worse
    for a while?
    The whining sounds like a worn out front pump (which is a
    hydraulic pump that creates the transmission fluid pressure
    needed for clamping large bands on turning components)
    You should probably remove the transmission oil pan and look
    for any metal fragments there which would indicate major
    components are failing and grinding themselves up.
    Since you are on a very tight budget you should try just cleaning the pan(expect to find some dark muck from wear of
    the "sacrificial" band lining and multiple clutch plate linings)
    but hopefully you will find no metal pieces. Try to baby it until
    you save up some trans. overhaul bucks.
    I would expect a noisy differential if the wheels are off the ground and it's running under no load.
    Be EXTREMELY careful getting under a raised running car.
  10. Spity
    Spity
    I had a similar problem with a truck I had, when ever I would hit the go-pedal hard my girlfriend would whine about me crashing. I solved the problem by getting rid of the girl and picking up one who liked to go fast.
    Seriously though.
    I had a u-joint on a front diff about to die, and it would scream so loud you would have thought the trans was going to die. 12 dollar u joint, no more whining.
  11. sobpunx
    sobpunx
    haha. the u joints are about a year old and they still look and feel good
    Yeah I'm really starting to think its the transmission, I will pull the pan in the morning, all I have is a carport, and its dark.
    thanks again for all your guys help
  12. Spity
    Spity
    Just drive it until something breaks.
    I would also suggest checking wheel bearings for kicks, they can also scream and make strange noises.
  13. sobpunx
    sobpunx
    I'm going to take it to my girlfriends moms this weekend so I can pull some **** apart.
    ohhh yeah it started all of a sudden
  14. Most guys not experienced waste a ton of money throwing parts at something trying to fix a problem. It would be worth it to spend a few bucks to get a driveline mechanic to take it for a spin to ****yze the noise. Ask around to find a reliable mechanic though......
  15. JC Sparks
    JC Sparks
    from Ohio
    Its the super charger, you got to much overdrive for the street. Just ****in with you. JC
  16. sobpunx
    sobpunx
    A buddy of mine has a guy in his car club that is a mecanic and a stand up guy I'll give him a ring
  17. Francisco Plumbero
    Francisco Plumbero
    from il.
    There are a lot of things it can be, pump, universals, a gear, a spark knock, could be a brake or even an emergency brake. I was fully convinced that I had a shot axle bearing, ready to swap out the rear, it was a broken piece of spring rubbing in the brake rotors, good as new for $45. Have a pro check it out, sometimes it's the best thing to do.
  18. poofus1929
    poofus1929
    from So Cal
    I understand what you are talking about. My o/t daily driver Ford's ****** whines. It almost sounds like a power steering pump that is low on fluid.
  19. sobpunx
    sobpunx
    that is what it sounds like but I dont have power steering and it started out of the blue.
  20. poofus1929
    poofus1929
    from So Cal
    It's the ****** pump. Mine whines, then stops, it's tempermental. It also started shifting hard. I am in the same boat as you, it being my only means of transportation. I am just gonna drive it until it goes then worry about it. It has been doing it for about 7 months now.
  21. sobpunx
    sobpunx
    ok so I do have some time before it completely goes. thanks, I'm still gonna go talk to some people and make sure that is the problem.
    thanks again everyone, sometimes I don't want to as questions here because their can be some jerks, you guys have helped me out alot and I really appreciate it.
  22. ironpile
    ironpile
  23. sobpunx
    sobpunx
    I'm taking it to a mechanic in the morning to have a look/hear thank god for buddies with mechanic buddies who are more than happy to help me out for free!
  24. sobpunx
    sobpunx
    Took it to the mechanic this morning and its the rear diff, he said its not that bad yet so I have some time to get some new gears and fix it
    thanks again for all your guys suggestions
  25. bobss396
    bobss396
    That's an easy fix. All you have to do is jack it up, pull the axles and the ham comes out with around 10 (?) or so nuts. Take an axle with you to the junkyard to make sure the splines of the ham you're looking at are the same. Wrap your u-joint cups to the u-joint with tape so they don't hit the deck and ****ter.
    The only other cost is new oil seals for the axles, the differential gasket and some gear oil.
    Bob
