Customs Window channel concern
Discussion in 'The Hokey Ass Message Board' started by ahshoe, Nov 8, 2020.
  1. ahshoe
    ahshoe
    Installing door gl*** in my project. I replaced the front window (wing window side ) the channel whiskers are new and a bit tight to run the door gl*** up and down. Any body have any luck with something that can be applied or sprayed into the whisker track channel so as the door gl*** will run up and down more smoothly?
  2. fordflambe
    fordflambe
    silicone spray from local parts house works great for me
    3quarter32 likes this.
  3. nochop
    nochop
    from norcal
    I would check with a gl*** installer myself, they probably got a trick or two
  4. mgtstumpy
    mgtstumpy
    I use graphite dust, windows glide up and down - smooth as silk. It comes in a small plastic puffer bottle.
    mcsfabrication and brigrat like this.
  5. brigrat
    brigrat
    from Wa.St.
    I always use a soap bar, works great depending on how tight it is to begin with. The soap works just long enough for the channels & gl*** to marry up after time.
    olscrounger likes this.
  6. BJR
    BJR
    Don't you get bubbles when it rains?
    brigrat likes this.
  7. RMR&C
    RMR&C
    from NW Montana
    x2 on the graphite
  8. fordflambe
    fordflambe
    Ummmm?...I can see the black stripe on the back of your forearm now................Heeeeeee Haaaaaaaw!
