i have a 1951 caddy 62 series 4door and was wandering if there is a side glass i can use from another car?
It's flat glass, any auto glass place can cut one for you. If they don't have a pattern use the glass from the other side for a pattern. Not very expensive either.
That's the problem with the autoglass industry..somebody will do it cheaper than the other guy. If a guy wants to stay in business, he has to charge more. $120.00 would be a going rate considering: cutting the pattern out of a stock piece of laminated glass, grinding the sharp edges down with a water injected sanding belt (machine), progressively changing to lesser grit belts and finally polishing the edges with a belt made by cork. This is the way I used to do it, and its good quality. I wouldn't do it for $25.00, not even worth it, time and effort.
