Hot Rods Window regulator install
Discussion in 'The Hokey Ass Message Board' started by i.rant, Apr 11, 2025.
  1. i.rant
    i.rant
    Need to replace a window regulator on my coupe, any suggestions or tips from any 40 owners would be greatly appreciated.
  2. 5window
    5window
    ***uming you have a 1940 Ford coupe-but you don't say...
  3. flynbrian48
    flynbrian48
    They are simply bolted to the inner door panel with machine screws. Take the door panel off, remove the gl***, unbolt the regulator, replace.
    olscrounger and i.rant like this.
  4. 19Fordy
    19Fordy
  5. Zax
    Zax
    I just removed mine last weekend on my Tudor to replace the gl***. Don't know if it's different than a coupe. But all I had to do was remove the upper bezel and vent window. Remove the handles (hardest part of the job). Remove the door panel. Remove about 6 screws that secure the regulator and left channel and then lower the whole thing out the bottom.
    i.rant likes this.
  6. olscrounger
    olscrounger
    Please note--some repo regulators do not have the stop cam on them and the window will drop right out when rolled all the way down.
    Algoma56, i.rant and 5window like this.
  7. i.rant
    i.rant
    Thanks everyone or responding, I wasn’t sure if I should tape the window “up” while switching out the regulator or not.
  8. garyf
    garyf
    To prevent ever to replace again .I have always used disk brake wheel bearing grease on the gear,track and rollers and any moving parts. It doesn't cake or harden up when old or cold.
