1952-59 Ford Window Regulator Issues (I think)
Discussion in 'Off Topic Hot Rods & Customs' started by earthbound, Feb 28, 2023.
  1. earthbound
    earthbound
    Hey guys, having an issue with my drivers side window where it won’t go all the way up after swapping out the gl*** and window track. It stops about an inch from the top. Prior to me owning the car some one cobbed up the window crank and looks like they welded the crank arm back together. Also, they had the regulator positioned different than stock. It’s a 55 Ranch Wagon.
    Anyone else dealt with something like this before? Do you think a new/original regulator will fix the problem?
    Thanks for all of your help in advance!
  2. Alan Freeman
    Alan Freeman
    Yes, it sounds like you need to replace the "cobbled up" window regulator and mount it in the correct stock position
  3. earthbound
    earthbound
    Thanks Alan! I put it back in the correct position already so hopefully I can track down a window regulator and that will solve the problem.
  4. Texas57
    Texas57
    Did a car show in Gainsville 4 or 5 years ago. I remember it was downtown near an old-time theater. I go thru there 3 or 4 times a year.
  5. earthbound
    earthbound
    Yeah that sounds about right! Been here almost 10 months. Next time through you should check out the old restored Gulf Station downtown just west of the square.
    Texas57 likes this.
  6. bobss396
    bobss396
    eBay is a great place to find regulators and other door parts for our old Fords.
    earthbound likes this.
