1952-59 Ford Window regulator rebuilds
Discussion in 'Off Topic Hot Rods & Customs' started by rwd_pete, May 10, 2015.
  1. rwd_pete
    rwd_pete
    The window winders in my Victoria are pretty rough and the driver side unwinds by itself. For one of my other cars I had gotten a kit with a new center pin and tension spring. Does anyone sell a similar kit for 56 vintage. All that I have found are for trucks and other year Fords.
  2. HOTRODPRIMER
    HOTRODPRIMER
  3. bobss396
    bobss396
    Post a picture of your regulator. I see them used on evilBay all the time and they may fit a spread of years.
  4. rwd_pete
    rwd_pete
    Thanks for the tips.
  5. fordsbyjay
    fordsbyjay
    from Lafayette
  6. buymeamerc
    buymeamerc
    from s.c.,usa
    a little paint remover, degreaser, and give 'em a citric acid bath. mine freed up great
    grease up and install, no rebuild!
  7. bobss396
    bobss396
    Nope, the '59 is different.
    I had an extra with my Ford, that went into the citric acid bath for a few days, came out pretty clean.
    And those springs are easy to find. C & G has them for sure.
    fordsbyjay likes this.
  8. 54vicky
    54vicky
    Larry's tbiird also has them a****st others listed above.
  9. rwd_pete
    rwd_pete
    Power windows would be nice especially in a hardtop. I've got a 62 Pontiac 4 door hardtop and I always wish I could put all of the windows down at once. It takes a longer arm than mine to reach accross the car.
    I think I will drill out the rivets and determine what the real issue is for the moment. Thanks for the ideas.
  10. 54vicky
    54vicky
    watch your fingers if you drill them out.as once the gear moves from rack the spring will want to unload.do yourself a favor and remove the spring first.
  11. rwd_pete
    rwd_pete
    As suggested, I pulled the spring out and found if you wind it one way it removes the tension and I still have all of my fingers, thanks. It appears that this one may just need cleaning and lubrication. 1956 Ford window winder Assy Top.JPG Winder internals and tension spring.JPG Winder gear drive.JPG
    Putting the window and sliders back together will be fun. Fortunately the other door is still ***embled for reference. There are many little screws and adjustments.
    Last fall I took a friend for a ride in the car with the windows down. The hardtop p***enger door closely nciely, but he slammed the door. Later when I rolled the window up the gl*** was cracked as I suspected. Lesson learned is give a door closing lesson in advance of taking on p***engers. LOL
    I bought replacement gl*** from Tee-bird products near reading PA. The prices were good and they had it in stock. It gave me an excuse to take my wife to the NHRA nationals at Maplegrove which is relartively close by.
  12. 55Brodie
    55Brodie
    Cracked gl*** is sure sign you need new window channel.
  13. 54vicky
    54vicky
    I would use white lithium grease as a lube
  14. buymeamerc
    buymeamerc
    from s.c.,usa
    lithium gums up or runs out(breaks down too fast for me) - used regular bearing grease on mine for durability/longevity
  15. bobss396
    bobss396
    For sure. Look at the fuzzies as well (anti-rattlers).
  16. rwd_pete
    rwd_pete
    I went looking for some new division bar type fuzzy strip. Most gl*** shops had seen regular channel, but not the stepped channel. I couldn't find it on the internet either. So I will glue some cloth in the track. Actually it looks like I probably did that some years ago. The lower window channel is a little shaky. I think I worked it over and brazed it when I redid the car around 1994. Tomorrow I get to try and ***embly the rubber channel liner, gl*** & channel. I'm not sure if it is typically glued to the gl*** and then trimmed after the fact, or to put on with rubber lubricant.
    The winder clean and rebuild went well.
    Getting the frame off the gl*** sprung it a bit, so I'll try and get it back to 90 degrees again before I fit it to the gl***.
  17. bobss396
    bobss396
