Technical Window regulator rivets
Discussion in 'The Hokey Ass Message Board' started by 392, Jan 18, 2019.
  1. 392
    392
    3277E7E8-C916-4D97-8767-D15BB2694A95.jpeg 25F36268-F4EE-46B6-82F1-06BA37CAD590.jpeg I’m wanting to remove arms etc from one regulator to duplicate another set for opposite side. My question is what are they called and where can you get new or similar. Or has anybody done something different to reattach when this fastener was used.
    Hnstray likes this.
  2. lothiandon1940 and Hnstray like this.
  3. mgtstumpy
    mgtstumpy
    Don't you mean window, not Windotor?
  4. 392
    392
    Yea that’s what it was intended to say. I’m not sure if a nyloc would work
  5. 392
    392
    I tried editing ***le but no luck. Maybe with stupid ***le more will look and either give good info or will remind me of proof reading before submitting.
  6. Moriarity
    Moriarity
    SUPER MODERATOR
    fixed the ***le
    kbgreen, lothiandon1940 and Hnstray like this.
  7. Moriarity
    Moriarity
    SUPER MODERATOR
    392
    Fantastic and thanks Moriarity. I’ll give them a call once I remove one and get size.
    lothiandon1940 and Moriarity like this.
  9. RMR&C
    RMR&C
    from NW Montana
    Don't those have a shoulder so the part can still rotate after being riveted?
    In the past I have ground off the riveted end, punched them out. Then reused them and welded the end back. But if they are worn badly that won't work. Let us know what you find.
    john worden and Moriarity like this.
  10. Moriarity
    Moriarity
    SUPER MODERATOR
    Yeah, they are probably shoulder rivets. But they do make em. Might be tougher to find, let us know how you do.....
  11. squirrel
    another reason to get a lathe, so you can make custom rivets, eh?
  12. You can get half nuts
    Sent from my moto g(6) play using The H.A.M.B. mobile app
  13. bobss396
    bobss396
    Are you inferring that there are people here than do not own a lathe???
    VANDENPLAS likes this.
  14. squirrel
    there are indeed such people. Strange though it sounds.
    Moriarity and VANDENPLAS like this.
  15. 392
    392
    I called Hansen rivet and they do carry semi tubular shoulder rivets. I’ll remove one and see if they have in stock on Monday and post update. And as far as lathe no I don’t and yes I would entertain if the right one would fall my way. Don’t need very often. Space would be issue also.
  16. HOTRODPRIMER
    HOTRODPRIMER
    You can find the tabular rivets at the bigger Ace Hardware stores with all the nuts & bolts/specialty. HRP
  17. Beanscoot
    Beanscoot
    "Are you inferring that there are people here than do not own a lathe???"
    They must be the "half nuts"! :p
  18. john worden
    john worden
    from iowa
    Why dis***emble the reg? I think you could easily measure the parts for reproduction purposes.
  19. miky2001
    miky2001
    from houston
    Danchuk sells them
  20. 30dodge
    30dodge
    from Pahrump nv
    I have used the "*** nuts" with loc***e ( like what is used in handsaws not the perverted type)
  21. 392
    392
    ED0D8C38-34DB-4D7D-B2C0-E18F3FA75764.jpeg C929BC2C-7C58-4742-A321-9328C899130B.jpeg Got rivets out. It is a complete shoulder that was pressed. I guess I could weld a washer then peen between tight and loose.
