Window Regulator rolls itself up
Discussion in 'The Hokey Ass Message Board' started by robbeky, Jul 28, 2013.
  1. robbeky
    robbeky
    from Kentucky
    I have a 1947 Chevy pickup window regulator that rolls itself back up (in a hurry) due to spring tension. I myself have not worked with this regulator and I'm not sure of the issue, the spring is intact and not broken. Is it possible someone along the way has taken this thing apart and re***embled with the spring backwards or something? Any ideas are appreciated.
  2. Okatoma cruiser
    Okatoma cruiser
    from Ms
    Springs gotta be in backwards. Unless its haunted!! Yikes!
  3. HOTRODPRIMER
    HOTRODPRIMER
    That spring must have a lot of tension on it to wind itself up,,be careful when you remove it. HRP
  4. R Pope
    R Pope
    Not in backwards, just wound one turn too tight.
  5. robbeky
    robbeky
    from Kentucky
    Thanks for the replies guys, i will carefully take it off and reinstall.
