Technical Window regulator
Discussion in 'The Hokey Ass Message Board' started by bobsundance, Jul 6, 2022.
  1. bobsundance
    bobsundance
    I have a 47 Chevy Fleetline 2 door both regulators have teeth missing on one end. Any idea what fits or where I can find two? Are coupe and sedan the same regulator? Mine is a aerosedan
  2. larry k
    larry k
    Weld “‘em” up and grind “‘em” to shape !!!
  3. Jim Bouchard
    Jim Bouchard
    ^^^ Yep, that’s what you do. ^^^
  4. oldiron 440
    oldiron 440
    This was my first thought…
  5. junkman8888
    junkman8888
    Another option is to find a regulator with a similar diameter gear, cut out a section where the teeth are and weld it in place.
  6. 19Eddy30
    19Eddy30
    from VA
    Like other have said , weld up & shape
  7. NoelC
    NoelC
    Both missing teeth? Were they taken apart? Just seems strange is all. Are you sure this isn't a case of not putting them back together properly?
  8. goldmountain
    goldmountain
    I agree with the others, weld and grind. Or replace them with these about 1990 or thereabouts Jeep Cherokee window regulators that have the same window crank splines as your old ones. The down side is that some modification is needed to fit the crank retaining clip. Since the Jeep has curved door gl***, the regulator needs a wee bit of straightening for flat gl***; something you can do with your bare hands. IMG_1597.JPG
