Technical Window Replacement ‘35 Buick
Discussion in 'Traditional Hot Rods' started by Olds Mike, Nov 30, 2022.
  1. Olds Mike
    Olds Mike
    from Spokane WA
    3BF52F7C-39BF-4D83-84B0-4D1B4A185394.jpeg A0A6CB16-335D-4CC6-BCC6-826FA4CAAFEB.jpeg Hopefully an early Chevy fan can help. Have a nice ‘35 3 window coupe. Need help with replacing the right door window. Yep there’s lots of wood. This Buick is a vintage early ‘60s build. It’s essentially the same car as a ‘33-‘34 Chevy. Before I start taking things apart I have specific questions:
    Do I have to remove the board the regulator is mounted on?
    Do I have to remove the vent window?
    Would like to hear from someone who has worked on a ‘33-‘35 GM. Thanks.
  2. mgtstumpy
    mgtstumpy
    Appears to be the larger Chevrolet 'Master' body, not the smaller 'Standard' body
    Here's the:-
    Crusty Chevy likes this.
  3. Olds Mike
    Olds Mike
    from Spokane WA
    Thanks Mgtstumpy. I actually do have the ‘33-‘34 Fisher body manual. It doesn’t give specific enough, for me anyway, directions on removing - replacing the door gl***. The instructions for removing the vent window are clear. I took a look at the ‘35-‘36 manual on line that you linked for me. Very similar to the ‘34 manual. I can, and will, continue to carefully work on removing the window. It’s loose. I’m certain that I need to remove the vent window allowing the bit of space needed to lift the window out. This ‘35 Buick means a lot to me. Have “known” the car since 1960 when its transition from a nice stocker to a ‘55 322 nailhead powered hot rod began. An actual legendary hometown car. Many changes with a couple owners prior to my taking stewardship. Currently 350/350/12-bolt powertrain. A nailhead might get reintroduced to its vintage engine bay. Thanks again!
    mgtstumpy likes this.
  4. 325w
    325w
    Pull the vent gl*** ***embly. Loose the lower gl*** Chanel from the regulator. Lift it out.
    The vent remote will need to be loosened from the lower vent shaft.
  5. Olds Mike
    Olds Mike
    from Spokane WA
    There it is! Thank 325w! Wanted to be sure I wasn’t removing or dismantling more than necessary.
