Technical Window seals
Discussion in 'Traditional Customs' started by Cndrodder, Jul 1, 2015.
  1. Cndrodder
    Cndrodder
    I am looking for some suggestions as to what would be the best adhesive to use for gluing the rubber vent window seals on my 1950 mercury. I have chopped both the front and real vent windows and have purchased new seals. Of course these things are not cheap so I want to make sure that if I cut and glue them that they stay in place.
  2. greybeard360
    greybeard360
    3M weatherstrip adhesive (use black). Put a little on the ends that need to be glued together and let it tack up, then stick them together. Same proceedure for gluing the weatherstrips in place. If you get a little bit on the paint, let it dry then put a little brake clean on a rag and wipe the glue off. I have used this stuff for a long time and it will hold a weatherstrip with a death grip so make sure it goes where you want it to be.
  3. LongLiveFlathead6
    LongLiveFlathead6
    Show us some pics of your chop...
  4. Cndrodder
    Cndrodder
    Here's a couple.
  5. 56premiere
    56premiere
    3M always works for me also. Black
  6. bobss396
    bobss396
    The black is fine. I believe I have the 3M 08001 here. It gives you enough time to position the part before it sets up.
  7. Cndrodder
    Cndrodder
    Thanks for the info!!
  8. 325w
    325w
    Super glue will hold the ends tight
