Hot Rods Windshield frame questions
Discussion in 'The Hokey Ass Message Board' started by Shinerunner82, Apr 28, 2016.
  1. Shinerunner82
    Shinerunner82
    from Alabama
    Just got my new windshield frame and I don't know how to attach it to the car? ImageUploadedByH.A.M.B.1461900580.615987.jpg ImageUploadedByH.A.M.B.1461900599.090813.jpg ImageUploadedByH.A.M.B.1461900609.195941.jpg
  2. on a `28-`29 the hinge is bolted to the underside of the header panel. you will need to drill the mounting holes in the hinge.i think on my `28 Tudor i also had to do some t*******
    in the picture an original hinge is already mounted
  3. Shinerunner82
    Shinerunner82
    from Alabama
  4. Shinerunner82
    Shinerunner82
    from Alabama
    So I can use the factory hinge?
  5. i believe that aluminum frame will work with the original hinge , give it a try. it appears the end of the hinge is bent over , you will have to straighten it out for them to slide together
    FYI.....i have the same windshield frame on my `28 Tudor. paid $105 for it in 1996. just bought an aluminum frame for my `30 coupe project and it was $279.
  6. alchemy
    alchemy
    If you can fit the new alum frame to that original steel hinge, it should give a much better life for you. Having alum rubbing on alum will cause galling.
  7. Shinerunner82
    Shinerunner82
    from Alabama
    Got mine from mikes a-ford able.com I think it was 240.00
  8. Shinerunner82
    Shinerunner82
    from Alabama
    I'm gonna try and use the factory hinge , thanks
  9. Shinerunner82
    Shinerunner82
    from Alabama
    Has anybody ever tried to use the factory steel hinge with a new aluminum frame, I've beat bent heated twisted cussed yelled oiled greased and cussed some more, they will not slide together. There's not a video or pictures out there with somebody doing this?
  10. just use the aluminum hinge that came with it , that's what i did on my `28 Tudor and it's been fine for 20 years
    using an aluminum frame and hinge on my `30 coupe
