Technical Windshield guy
Discussion in 'Traditional Hot Rods' started by mandriano, Apr 11, 2022.
  1. mandriano
    mandriano
    I want to change my windshield rubber on a 40 Ford, have a new Drake rubber. looking for someone in the Atlanta, GA area
  2. 19Fordy
    19Fordy
    You can do it yourself with a helper. I did mine 40 years ago using a DRAKE rubber. seal. My car is a coupe.
    Do not use silicone sealant you find at Lowes or Home Dept.to seal the glass as it doesn't work.
    Use the correct glass sealer. Check this out.
    https://www.walmart.com/ip/CRL-CRL7...q4LBDfKZJLXI1U8LXXBoCSnoQAvD_BwE&gclsrc=aw.ds
    Also, ask your question on Fordbarn as thee might be someone there who lives near you who can help.
    https://www.jalopyjournal.com/forum/threads/1940-ford-windshield-correct-installation-how-to.929811/
    http://www.vanpeltsales.com/FH_web/flathead_glassinstall-40-46_pg1.htm
    Also, more info. here.
    https://www.google.com/search?q=cha...rome..69i57.9729j0j4&sourceid=chrome&ie=UTF-8
    When you reinstall the garnish moldings wrap the tip of the flatblade screwdriver with electrical tape to prevent damage should the screwdrive slip out of the screw slot.
    chryslerfan55 and olscrounger like this.
  3. Easy. Cut the old rubber with a razor knife, pop the glass out replace with new rubber.
  4. 19Fordy
    19Fordy
    Perfect example of: "Easier said than done".
    chryslerfan55 and '49 Ford Coupe like this.
  5. geoford41
    geoford41
    from Delaware
    I believe a helper on the inside pushing against the glass keeping pressure on as another person on the outside pulls a cord out lifting the rubber gasket over the "pinched" area of the windshield. I just did a headliner on my 1940 so I had to cut out the rubber gaskets on the quarter windows and rear windows, so after I finished the headliner install I put new gaskets on the quarter windows (easily installed, without having to lift a rubber flap over the body). The rear windows usually require 2 people but I was able to do it by myself with a little persuasion and soapy/Windex spray to release the cord. Just make sure you push the gasket/glass into the opening from the inside so it is close to seating before using the cord to lift the outer flap.
