1952-59 Ford Windshield & Rear Glass Stainless Question
Discussion in 'Off Topic Hot Rods & Customs' started by baker53, Aug 13, 2010.
  1. baker53
    baker53
    When replacing the windshield or the rear gl*** on a '53 Ford Victoria, does the stainless steel trim get placed into the rubber seal before the gl*** is installed into the car or afterward?
  2. JeffB2
    JeffB2
    from Phoenix,AZ
    It has to go in at the same time as the windshield and seal as per the Ford Shop Manual.The seal is what holds the stainless in,if you were to try to put it in after you will probably crack the gl*** or bend the stainless,also if you are replacing the headliner the rear gl*** must be removed so it is best to do both at once.You may want to check out www.usapartssupply.com for the seals and their headliner prices are from $99 and up.
  3. baker53
    baker53
    Thanks for the info...
  4. Copper Top
    Copper Top
    Jeff, thanks also for the link to usaparts supply. I downloaded the catalogue.
  5. Retro Jim
    Retro Jim
    Jeff , thanks for that link also ! I just order a catalog too . That one will cover my 49 , 50 & 55 Fords !
    Jim
