windshield wiper motor
Discussion in 'The Hokey Ass Message Board' started by hotrodder3, Jun 17, 2007.
  1. hotrodder3
    hotrodder3
    from maine
    What are you using for a wiper motor
    i have a 40 ford pickup with va***e wipers--want to change to electric
  2. Paul2748
    Paul2748
    New Port Engineering makes a kit for this. I ***ume you have 12 volts.
  3. Dirty2
    Dirty2
  4. 39 Ford
    39 Ford
    Drake has a kit that looks factory, not a cobbled up add on. Check it out.
  5. 51 pickem up
    51 pickem up
    from mosheim,tn
    i used one of theirs in my 51 chevy pickup mounted pretty easy.
    make sure you mount it before you mount anything under the dash.
  6. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    I've had bad luck with New Ports stuff.
  7. Lobucrod
    Lobucrod
    Alliance Vendor
    from Texas
    speciality power windows kit. Its a ***** to install but works like a charm. Even has a delay function.
  8. hotrodder3
    hotrodder3
    from maine
    this is a hot rod --NOT A KIT CAR---doesnt anyone adapt junk yard parts anymore (yes it has 3 pedals too)--im looking for a small motor in size to adapt to my 40---not a kit-----i do appreciate the people that answered & do want to thank them ---im old school so its too late for me to change--this is a low bucker not a jay leno endless pocket mobile
  9. Lobucrod
    Lobucrod
    Alliance Vendor
    from Texas
    No problem, Good luck
  10. docholiday72tx
    docholiday72tx
    Hot rodder, I have a 41 that I want to do the same thing as your doing. I don't have any specifics yet, but I found an old VW bug wind shield wiper motor that is pretty compact looking that Imay try to use.
    Doc
  11. man-a-fre
    man-a-fre
    dual wiper set up from early toyota land cruiser.......... .
  12. F1James
    F1James
    I dont recall what year it was from but i used a VW motor and wiper tranmission on a 50 F-1 had to move the shaft holes about half inch closer together and do away with cowel vent bur wipers worked fine.
  13. its_a_nick
    its_a_nick
    from Sweden
    I used one i had lying around from a boat:eek:
  14. hawk40
    hawk40
    from us
    i,m using mighty wiper single speed, in my 40 cost u about 100 bucks a side.
    not as fanacy as newport and others and not junk yard swap but they are compact and not 300 plus dollars either.
  15. hotrodder3
    hotrodder3
    from maine
    the body shop up the street has a bunch of cowls left over from noses he bought --gonna look to see if i can find one that will work---will let you know if i find one that works---many body shops will let you have something out of their junk pile for free---i got a camero 5 speed that way too
  16. 53sled
    53sled
    from KCMO
    arctic cat snowmobile kit. $15
  17. junkyardgenius
    junkyardgenius
    from Kernow
    Just fitted a 6volt electric wiper motor to my wife,s 54 Chevy, took off the vacuum motor and made a bracket to hold the electric one also made up a little adaptor and welded it to the shaft on the electric motor ,works great.
  18. Mine are out of a 57 Chevy that was in a junk yard in California with the back end cut off. Rags
  19. Gman0046
    Gman0046
    Had a Specialty unit on a 46 Ford and it was worthless. Had to use RainX anyway. Keep your vacuum unit, save $$$$$ and use RainX. Spend your money on something worthwhile.
  20. PeteFromTexas
    PeteFromTexas
    I DON'T SEE WHY IT WOULD MAKE IT A "KIT CAR" BY PUTTING SOMETHING "NEW" ON IT
    IF IT IS A SAFETY ITEMS SUCH AS BRAKES, STEERING, AND WIPERS. IT SEEMS TO ME THAT IT WOULD BE WORTH WILD TO HAVE PARTS THAT WILL WORK. NOT OLD JUNK. PUTTING ON A NEW PART HERE OR THERE DOESN'T MAKE IT A "KIT CAR"
    USE WHAT YOU WANT. I DON'T HAVE ALL KINDS OF MONEY TO DUMP INTO NEW PARTS BUT THERE ARE A FEW THAT I WOULD LIKE TO KNOW WILL WORK WHEN I NEED THEM.....PEACE OF MIND IS WORTH A LITTLE EXTRA MONEY IN MY BOOK
  21. fasteddie
    fasteddie
    from mass.
    try one of the many headlight wiper unit's out there.small,comp.and many out there..saab.volvo,bmw,vw you name it.
  22. 38mag
    38mag
    <TABLE id=HB_Mail_Container height="100%" cellSpacing=0 cellPadding=0 width="100%" border=0 UNSELECTABLE="on"><TBODY><TR height="100%" UNSELECTABLE="on" width="100%"><TD id=HB_Focus_Element vAlign=top width="100%" background="" height=250 UNSELECTABLE="off">I used a motor and parts from a MG. The motor mounts under the dash and a cable runs through a tube to the wiper transmissions.
    Works great and is easy to install and wire.
    </TD></TR><TR UNSELECTABLE="on" hb_tag="1"><TD style="FONT-SIZE: 1pt" height=1 UNSELECTABLE="on">
    </TD></TR></TBODY></TABLE>
  23. 38mag
    38mag
    <TABLE id=HB_Mail_Container height="100%" cellSpacing=0 cellPadding=0 width="100%" border=0 UNSELECTABLE="on"><TBODY><TR height="100%" UNSELECTABLE="on" width="100%"><TD id=HB_Focus_Element vAlign=top width="100%" background="" height=250 UNSELECTABLE="off">I used a motor, wiper transmissions and drive cable from a MG. The motor mounts under the cowl and the drive cable runs thru a tube from the motor thru the "A" piller to the wiper transmissions. This system works great, is easy to insall and easy to wire.
  24. budd
    budd
    i run a new wiper motor i pick up at a surplus store here called princess auto, it was about $19, has 2 speeds and park, i only run one switch on low speed and time my shut off so the wiper ends up where i want it to stop, i made my linkage out of old carb linkage and then welded an arm to the wiper shaft.works great, one day i`m going to run 2 wiper and hide my motor under the header panel.
  25. hotrodder3
    hotrodder3
    from maine
    I really want to thank all that responded to my windshield wiper question--you all gave me some great ideas & i really appreciate it---the hardest part of being an old rodder is most of the parts you would have used before are either not around anymore and besides --who keeps up with the new car ****--the best part of hotrodding is to find a part & make it work--the pleasure you get outta building a car the old way is tremendous--& when it does what you want it to---thats heaven---nothing better than cruising around in something you built--again --thank you----long live the hamb
