Hot Rods Windshield without a frame, can it be done
Discussion in 'The Hokey Ass Message Board' started by Johnson's Fab Shop, Jan 4, 2022.
  1. Johnson's Fab Shop
    Johnson's Fab Shop
    E29B1F07-4FC1-4BB0-9137-AE96CCFEFDBD.jpeg Ultimately I’d like to have the option to swing the windshield forward at the bottom or back at the top as desired. That’s why I was going to run the ‘32 stanchions on my ‘29. Similar to this model A. In the end I’ll probably end up making a frame out of stainless
    oliver westlund and desotot like this.
  2. Flathead Dave
    Flathead Dave
    from So. Cal.
  3. Johnson's Fab Shop
    Johnson's Fab Shop
    I’m leaning towards that option. It would be a fraction of the price.
  4. gimpyshotrods
    gimpyshotrods
    Check your local laws. In some places that could be a ticket and/or impound.
    Flathead Dave likes this.
  5. Paul
    Paul
    Editor
    Just a thought experiment, what is the psi pressure from wind resistance exerted on the windshield at say 70 mph?
    Imagine laying the windshield flat supported only at the ends as you describe, like a bridge. Now stack sand bags on it. At what point does it fail? Does it support that psi? How many psi at 90 mph into a 15 mph headwind? Can it support that? Will it support a margin of safety of 100%? When it fails will it stay supported by the ends or will it come loose? If it comes loose where will it go?
  6. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    Yep exactly.
    Trailer queens for a reason.
  7. Flathead Dave
    Flathead Dave
    from So. Cal.
    This is true. I didn't think about this.
  8. twenty8
    twenty8
    OUCH...!!!:eek:
  9. They made boat windshields without a frame and I have seen them on hot rods before.
    If you can work with lexan you can do it easy enough.
    dana barlow likes this.
  10. Or folks can read what I posted in Post #10 where I actually have done this and it has been on the road for 15+ years and about 25K miles
  11. Paul
    Paul
    Editor
    Trent's version with the "T" seal at the lower edge is getting support from the body.
    The op suggested an air gap along the bottom with vertical support only at the ends.
  12. Mine did rest on the cowl but you could slide a business card under the seal if you wanted. With the modern Urethanes I think you COULD float it with no ill affects but it would look way to modern to me. In my eyes the rubber mellowed out the look a bit and helped the imperfections between gl*** and cowl hide.
    Paul and twenty8 like this.
  13. JWL115C
    JWL115C
    I made a frameless windshield for my 30 A Roadster. I cut down the standard stanchions, then cut a groove in them to hold the gl***. I had a windshield cut out of safety gl***. Safety gl*** rather than tempered gl*** or plexigl*** because it was safer and less expensive. It had a slight curve at the top and the bottom followed the shape of the cowl with a slight gap so it did not touch the cowl. Looked nice. Easy to do.
    Tman likes this.
  14. Johnson's Fab Shop
    Johnson's Fab Shop
    That’s basically what I am thinking about
