Technical Wing tank car first drive
Discussion in 'Traditional Hot Rods' started by Truckedup, Jun 14, 2014.
  1. Truckedup
    Truckedup
    Got it jury rigged for a ride around my driveway. Bad carburetion but it does move ,vice grips for a steering wheel and a bunch of jumper cables and wires.
    I ran it for about 1/2 hour and the water temperature stayed around 160 degrees on this cool 60 degree day.
    And a burn out...
  2. tfeverfred
    tfeverfred
    I love it! Hot Rodders have NO shame.:D
    volvobrynk likes this.
  3. Paul
    Paul
    Editor
    haha! very cool!
  4. Erkenbrand
    Erkenbrand
    That was awesome. Well done.
  5. summersshow
    summersshow
    from NC
    Nice! Got the body going yet? Cant wait to see
  6. 26 T Ford RPU
    26 T Ford RPU
    Too cool Tony. JW
  7. Truckedup
    Truckedup
    Well,it was all fun and games ...then.... The engine stumbled from carb problems but besides that it seemed to have a dead cylinder again... Sure enough the last cylinder on the right wasn't firing despite good spark. I pulled the spark plug and it smelled funny,like water mixed with gas.The oil showed excessive condensation..I drained the water,cleared the cylinder and fired the engine for 30 seconds. It ran great on all eight.....I pressurized the cooling system to 5 PSI and after a few minutes ****ing water came out the spark plug hole. I pulled the head, no head gasket leak... Couldn't see any obvious defects in the head or cylinder ...I pried open the valves to have a look inside and there was water droplets there in the intake valve bowl.I don't know if it was from somewhere else or whatever...
    Before building the car the engine was put on a stand, removed the oil pan ,front timing cover ,intake and heads and had a close look.The left rear cylinder has a sleeve and a weld repair ....I put the heads and front cover back on ,filled the block with water (with detergent added to remove surface tension) and pressurized it for several days.No leaks to be seen so I put it all together and called it good to go....Not really...
    I built the car for my race bike rider in trade for a bike I wanted. He says can we fix it???...I say I don't know ,have to pressure check the head somehow and then maybe the block...I work on vintage British bikes not old Fords
    So....It might be best to ditch the V8 60, sell the Meyers dual carb intake and other good parts.Use the money to get a 4 cylinder engine of some sort. making new motor mounts and adapting a different ****** to the banjo open drive rear is no big deal... He does have a running Model A engine and ******....I have to measure the length because it can't be longer than the V* 60 set up and shorter would be nice....
    It will run again...
  8. little d
    little d
    from sedalia mo
    Truck,
    before ya swap out motors, my Dad showed me a trick, he called it "Water Gl***", ya get it at the pharmacy (has a chemical name but I forget it now). Anyways, ya flush out the system and add this and water, let it circulate for a while and it will find any cracks, filling them up. Flush it out and fill back up with antifreeze and you should be good to go...If I remember, it was only like a few bucks, might be worth trying?
  9. HOTRODPRIMER
    HOTRODPRIMER
    I was gonna say this Looks and sounds like the typical red neck "Hey guys watch this" fiasco..but then again since I have done something very similar it occurred to me you are not the first person to embark on such a pleasurably lark.
    We often get overzealous and something goes wrong,I hope it's nothing major. HRP
  10. weps
    weps
    from auburn,IN
    now THAT is why it is nice to have a circle driveway!
    sorry to hear about the leak, but there are a lot of products out there to try to fix it.
    at this point you have nothing to loose, everything to gain if the leak seals up. Also unless you really want a pressurized system, try running it with no pressure (like the old cars did) see how that works out.
  11. summersshow
    summersshow
    from NC
    Moroso makes a ceramic additive that works great for minor hard to find leaks... Are you sure you have the right Gasket? I had the same problem with a '40 flatty. It was the head gasket, it was cut wrong on the driver side, it came from Egge. They sent me a replacement, put it on problem all gone.
  12. Truckedup
    Truckedup
    Laying a straight edge on the aluminum head shows it's warped about .015 with the center contacting the block before the ends.. The dead cylinder is an end one... Even though the head gasket looks like no leaks...who knows. Probably 60 bucks to have the head milled and another 50 buck head gasket. I'll meet with the car owner tomorrow, It's his decision take a chance fixing it or whatever...But being the frame is built around the engine it's likely worth the risk.
    It's the correct head gasket....And the cylinder will misfire even with the radiator cap off so it's probably ****ing water on the intake stroke.
  13. Ol Deuce
    Ol Deuce
    from Mt. U.S.A.
    You have a very Cool start on your tank Project!!!!
  14. Ol Deuce
    Ol Deuce
    from Mt. U.S.A.
    This was my start!!! Tanks are way Cool!!!!
  15. 26 T Ford RPU
    26 T Ford RPU
    That they are !! JW
  16. seatex
    seatex
    Oh man, I love it! I GOT 'DA FEVAH! Subbed!
  17. BillyG
    BillyG
    Water gl*** is also known as sodium silicate. Google it. A friend of mine uses it to seal the cooling systems on the flatheads he builds. It has to get hot, then you drain that and refill cooling system.
