Wing window question 51 chevy
Discussion in 'The Hokey Ass Message Board' started by cody1958, Sep 7, 2013.
  1. cody1958
    cody1958
    from wichita ks
    My wing window will not stay in the open position on my 51 chevy car. Is there an adjustment bolt or something that will allow this to stay open. I get going about 20 mph it will always blow closed on me. .
  2. 302GMC
    302GMC
    from Idaho
    There's a spring under there that's adjustable. The stud can break or the nut fall off. I seem to remember adjusting them just by pulling the garnish rail, but ???
  3. metalix_421
    metalix_421
    agree with 302 but I think you pull the door p**** and there is a hole right under the window to access the nut to ajust it.
  4. S.Sutherland
    S.Sutherland
    from Fontana,CA
  5. 325w
    325w
    The nut has a lock on it. You'll have to pry the two sides up. Soak the nut before you try to move the nut. You can easily twist the stud and break it loose from the vent frame.
