Projects winter project - "so let's chop a 40 coupe (and fab everything else possible...)
Discussion in 'The Hokey Ass Message Board' started by zibo, Feb 16, 2009.
  1. 38FLATTIE
    38FLATTIE
    from Colorado
  2. 41 Dave
    41 Dave
    Travis, Can not see the pix from Irish Mike. . . Got me all excited about crank driven supercharged Caddy V-8 . . . . . .
    Dave
  3. I didn't scan that, but I like it!!!!
  4. catman
    catman
    from El Reno
    I don't post much on here but... you sir, are a craftsman on a higher level...
  5. 41 Dave
    41 Dave
    Travis, Any luck getting that pix from Irish Mike to show up ?
    Getting all charged up about crank mounted super charged Caddy V-8 !
    Dave
  6. joel torres
    joel torres
    im still subscribed and up to my patching on my project and i have to tell ya it builds my confidence you make it look easy your car is looking great
  7. 41 Dave
    41 Dave
    Travis, Looking forward to the next update on your coupe.
    Dave
  8. DYNODANNY
    DYNODANNY
    Hury up on the up dates.
  9. attitudor
    attitudor
    from Finland
    Dig the salt flats flavor... That's a m***ive amount of work done there. Keep it going!
    --mika
  10. BACAGrizz
    BACAGrizz
    Just read this whole thread. Awesome build. Great work. Looking forward to seeing the finished project.
  11. zibo
    zibo
    from dago ca
    Ok,
    here's a quick coupe update.
    I have a soft goal of at least finishing the sheetmetal by the end of summer.
    There's alot of sheetmetal.
    Here's where I left off the back.
    The decklid is welded shut,
    so all this work is crawling in the door into the rusty cave.
    The fenders were welded to the body,
    but the bolt flange was never cut off.
    I figured it could be handy to weld the inner wheelwells on,
    but it was just too nasty.
    The plan was to hide the reinforcement in the wheelwells,
    so some tube was bent up and welded close to the seam.
    Than some triangle brackets were whipped out,
    hopefully this will spread the load on the body.
    Than a cardboard form was made,
    and some light tubing bent to a decent shape.
    After that a couple little tabs connected the tube to the body,
    than some tabs welded from the tube to the hinges.
    (There is a channel drip rail welded to the top part of the body there now too)
    The decklid was tacked to the body,
    so when that drip channel on the top part was welded on
    (from the inside)
    I was hoping it would keep its form.
    The tacks were cut and there was no popping.
    Whew.
    Way more rigid than with the temporary hinge base setup.
    (which is now the 40's bike rack!)
    TP
  12. lockwoodkustoms
    lockwoodkustoms
    Zibo...........I love it and have been watching from the start damn your amazing.
  13. zibo
    zibo
    from dago ca
    My uncle had conveniently s****ped some old lockers from his work,
    and they happened to be a decent 20 gauge sheetmetal,
    not that chintzy stuff thats made now.
    Only bummer is its painted but that's ok.
    Although the back is open,
    for some reason I started in the front.
    The tricky part,
    is first there needs to be a subrail,
    attaching the bolt on pads,
    than the sheetmetal fills that gap.
    There's also the bottom hoop for the firewall,
    so now the gap I need to fill is more obvious.
    There is a light reveal kinda hammered into the metal.
    It's not perfect but I'm not too worried as its inside.
    It's all hammered on this stand,
    cause I don't have a bead roller yet.
    It's nice to not see a big gaping hole.
    By the time all the pieces are done,
    I'll be way better at freehammering reveal lines!
    I started on the back too,
    and this will probably be a mistake.
    First the subrail pieces...
    Its a mistake cause the big tires cannot be removed without
    dropping the rearend.
    I'll have to radius the fender curve a little more soon.
    and covering up such easy work access will make it harder.
    I shoulda also wirebrushed the inside,
    but wasn't to keen on getting me or the shop dirty.
    It's hard to see but I did clean barely enough paint off the edge!
    That's where I'm at right now.
    TP
  14. koolkemp
    koolkemp
    X2 !! I always enjoy the updates on this amazing transformation !
  15. 29ToyA
    29ToyA
    WOW!!!!!!!!
    Awesome build!
  16. gassercrazy41
    gassercrazy41
  17. Strange Agent
    Strange Agent
    How have I never come across this thread before?! You're doing killer work on this thing!
  18. 41 Dave
    41 Dave
    Travis, Body is really starting to come together. Looking forward to more progress as you repair that old coupe body. May have to visit again and get some progress shots.
    Dave
  19. koolkemp
    koolkemp
    "I shoulda also wirebrushed the inside,
    but wasn't to keen on getting me or the shop dirty."
    If you blow it apart when all the fab work is done, just give a quick p*** on all the underside panels with a sandblaster , a shot of metal prep then prime/paint call er done !
  20. zibo
    zibo
    from dago ca
    Thanks guys!
    I dropped off a dis***embled '57 chevy truck to the sandblaster/painter we use at work...
    http://perichbrothers.blogspot.com/2011/04/hurtlocker-truck-stripper-time.html
    http://perichbrothers.blogspot.com/2011/06/la-cucaracha-hurtlocker-truck-returns.html
    and if my finances and time permit,
    it's a definite possibility to have it professionally done by these guys.
    (They use an epoxy primer)
    I'm just really cheap when it comes to my own stuff!
    TP
  21. D-n-Tyke
    D-n-Tyke
    Hey Zibo, you are the man, I could only dream of having your metal working skills. Keep up the good work. Where are you guys located? Seems like you aren’t too far away from me (El Cajon area). I think you will be very happy with El Dorado, We used to use them when I worked at a VW restoration shop here in town. NEVER had a problem with anything they ever did for us.
  22. 41 Dave
    41 Dave
    More Travis more . . . . . Go Man Go !
    Dave
  23. koolkemp
    koolkemp
    Go for it, money well spent! The car is way too cool to let it continue rusting! I am just as cheap lol !!So you know how hard this is for me to say :rolleyes:
  24. zibo
    zibo
    from dago ca
    Saw this video on here last week and it gave me a little nudge to get a move on the coupe.
    http://www.youtube.com/watch?v=ZiIu5gQUT_s
    <object width="425" height="349"><param name="movie" value="http://www.youtube.com/v/ZiIu5gQUT_s?version=3&amp;hl=en_US"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/ZiIu5gQUT_s?version=3&amp;hl=en_US" type="application/x-shockwave-flash" width="425" height="349" allowscriptaccess="always" allowfullscreen="true"></embed></object>
    Thanks Dreddybear!
    I don't need the shiny though.
    I'd be happy as a 40 footer!
    (This was the 50's version of the doug rice coupe,
    after the maroon)
    My biggest stumbling block is the firewall.
    The engine is so set back its tough to make a flat firewall,
    without taking up pedal or foot space.
    So last week figured a gap filled ugly is better than nothing.
    It looks like a smokestack coming out of a mailbox.
    The sheetmetal is from a s****ped locker.
    Yes,
    I tried to wirewheel the paint off the main weld seams,
    but it was a half-*** attempt,
    and my welder could burn through alot faster.
    The trick is to wirebrush right after welding.
    Puts those shop fans and respirator to use.
    The inside part isn't too bad.
    The engine side needs to be trimmed, welded and cleaned up.
    With the firewall dimensions set,
    the engine can finally be removed.
    I've been waiting for this part a long time.
    The bummer is my floor space is so crowded I've got to clean the shop first!
    TP
  25. billys54
    billys54
  26. James D
    James D
    I love this car.
  27. koolkemp
    koolkemp
    I think the firewall looks great, cant wait to see it from the other side!!
  28. 41 Dave
    41 Dave
    Travis, If you need any volunteer labor to clean the shop just let me know. I ***ume it would be weekend only. I would love to help.
    Dave
  29. Harms Way
    Harms Way
    Just utterly astounding !
  30. nitrohonkey
    nitrohonkey
