Art & Inspiration Winter storage tips for easy spring dust off.
Discussion in 'The Hokey Ass Message Board' started by flynbrian48, Apr 19, 2023.
  1. flynbrian48
    flynbrian48
    We got back from Florida on Friday, the first thing I did was go out to the shop and fire everything up. Thanks to my exhaustive winter prep routine, everything started instantly.
    Here are the steps I took to ensure worry free fire-up after 6 month storage:
    1. Pull car(s), motor scooter, lawn mower, utility tractor, whatever, into the garage.
    2. Carefully turn key to "OFF", and exit vehicle.
    3. Open hood (or trunk, depending on battery location), and put a Harbor Freight $10 battery tender on, making sure to plug it in and the little red light comes "ON".
    4. Shut garage/shop/storage unit door and walk away.
    (Note that on this roadster with it's original, 1952 fuel pump and carb, I did disconnect the fuel line at the pump, started it and ran it until the carb and fuel lines were empty. )
    5. Come back 6 months later, turn the key to "ON", then fire 'em up. In the case of carbureted vehicles (like my roadster here) who's carbs are empty, the cranking period may be 10 or 15 seconds, and may require some gas dribbled in the carb. I didn't, but I did give it a whiff of ether.
    Follow these simple steps, and winter storage doesn't have to be complicated or frustrating! DDC63434-7A2B-4CFB-81EE-06ADADBB2EF5.jpeg D1DF3C55-8B02-445F-9EAD-8333EBE3F3B0.jpeg 1B72B970-8E27-4539-87C7-20F16F5468AB.jpeg
  2. GordonC
    GordonC
    Looking good Brian!
  3. BamaMav
    BamaMav
    from Berry, AL
    I’d be scared of those HF battery tenders. All it would take is one to short out and there goes everything.
    I’d just disconnect the batteries and stick them on a real charger when I got ready to get the cars out.
  4. 57 Fargo
    57 Fargo
    That’s about my storage routine as well Brian, however I skip the battery tender step and my junk still starts in the spring!
    VANDENPLAS likes this.
  5. BJR
    BJR
    All my small engines, like lawn mowers, chain saws, weed wackers, etc I try to run out of gas. Same with the snowblower in the spring. Keeps the carbs from mucking up. And they always start when it's time to use them again.
    flynbrian48 and NashRodMan like this.
  6. NashRodMan
    NashRodMan
    You didn't tell us how to dust them off! :D:rolleyes:
    flynbrian48 likes this.
  7. flynbrian48
    flynbrian48
    I didn't have to! They're all still clean! When the doors aren't opened, the dust doesn't fly around I guess...
  8. 1971BB427
    1971BB427
    from Oregon
    I have one Exide, and two HF battery tenders. All are almost 20 yrs. old, and still use them every winter on my 3 cars. No problems with any of them, cheap or expensive.
