Hot Rods Winters Rearend question
Discussion in 'The Hokey Ass Message Board' started by 1oldtimer, Feb 27, 2025.
  1. I didn't want to hop on anyone else's thread. Has anyone used a Winters "No Change" rear. How close was it to looking like a stock banjo and do the bells have an o ring or gaskets to adjust like the stock banjo?.
  2. hrm2k
    hrm2k
    I haven’t so I went and took a look . Holy **** !!! They ain’t cheap !!!
    I would think they would match up. I saw that Speedway has one. You might be able to get any questions answered there.
    Good luck
    mad mikey and lothiandon1940 like this.
  3. krylon32
    krylon32
    from Nebraska
    I've done a couple on customer ch***is. To dam expensive, not much bang for your buck. V8 QC is a better deal.
    HemiDeuce likes this.
  4. Mr48chev
    I've to agree with Krylon32 that is a lot of fun tickets to spend to have a rear that looks like a stock Ford Banjo from 3- Ft. I see the point of having new and stout gears and axles though. Screenshot (197).png Screenshot (200).png
    mad mikey, lothiandon1940 and hrm2k like this.
  5. DDDenny
  6. In case it doesn't pop up with the link.
  7. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    I have an NOS Halibrand differential and R&P. Will fit in an original Banjo.
    These are not a limited slip, but they have 31 spline side gears and will accept push in axles.
    Send me a conversation and I'll give you the specifics.
  8. Do these (I ***ume the new quick change is the same) use and o ring or gaskets on the bells. More importantly do you need to shim the bells for bearing adjustment like the stock banjos? or are these just bolt on and go.
  9. alchemy
    alchemy
    Gaskets are shims, just like Henry did it.
  10. This is how I did it.
  11. The parts break down shows that the V8 center section (Bruce's) is the only one with gaskets/shims. All the others show just an o ring, but they do have tapered side bearings...so everything is machined just right???
  12. gimpyshotrods
    gimpyshotrods
    There are two no-change center sections.
    Champ and V8.
    V8 is the Ford car size.
    Both are shimmed with shims under the carrier bearings.
    Mixing the two might require a combination of shim gaskets, and carrier bearing shims. Either way, not a big deal.
    They look Ford-enough.
