Technical wiper blade refill
Discussion in 'The Hokey Ass Message Board' started by msgt tank, Aug 27, 2024.
  1. msgt tank
    msgt tank
    do you know where we can buy wiper blade refills? it measures 9 inches.
  2. 57 Fargo
    57 Fargo
    I’ve been buying new wiper blades and dissecting the rubber from them to rebuild old ones.
  3. inthweedz
    inthweedz
    Not sure about where you are, but here in New Zealand, insert replacements (rubber only) are available to suit most cars. I find the right end section shape, and cut to length..
    msgt tank and Algoma56 like this.
  4. JohnLewis
    JohnLewis
    Use to keep trico refills behind the counter when I worked at oreillys. But that's been over 5 years or more.
    partssaloon and msgt tank like this.
  5. @57 Fargo @inthweedz beat me to it, but I used to do the same when needed. Match the cross-section of the rubber wiper, and cut to length.
    winduptoy and msgt tank like this.
  6. In_The_Pink
    In_The_Pink
    Looks like you have a Trico Rainbow wiper blade in there currently, like so: https://www.ebay.com/itm/235394328771
    As suggested, get a good close up view of the cross-section (or just view it end on) of the rubber blade itself, find an older blade with a matching profile, and trim to length. You should be able to bend up one of the end tabs on you wiper blade body to get the old one out.
    msgt tank likes this.
  7. Davesblue50
    Davesblue50
    leon bee and msgt tank like this.
  8. You want to be careful when doing this. The blade frame that holds the refill can wear out at the little 'channels' that hold the refill. If one breaks in half while in use, it can trash your windshield in nothing flat. AMHIK....
    Make sure those channels aren't too worn, that stainless isn't very thick.
  9. 57 Fargo
    57 Fargo
    Every old car/truck I drive I have done this with, to me it’s a given to ensure it’s not going to fall apart.
  10. '29 Gizmo
    '29 Gizmo
    from UK
    9" is a common size for rear screen wipers. Should be easily available at the parts store. Look for 230 in the part number.
  11. brading
    brading
    Have a look on Amazon they have them on there.
  12. gene-koning
    gene-koning
    I just picked up a pair of 10" from Orilly's a few days ago, had them in stock in the store.
    I found out I could order them on line to pick up at the store, and save $3 each over what they cost to walk into the store and buy them! According to the salesperson, the store can't even match its on line pricing. I'm thinking that is BS, but that was the way it went down. just a heads up.
