hello Anyone have ideas about a wiper motor (electrical) easy to install on the windshield of a Model A, at the top so it is hidden into the vehicle
Mighty wiper from Pacific Western Design Inc. Used them in my '34 - very small so they fit behind the header panel and worked great. http://www.pacificwesterndesign.com/Mighty/index.htm
Thnaks a lot I was thinking on some used motor I can adapt to work in the model A. Does anyone have seen a techinical treat about it ????
Irapso, check out late model Jeep cj rear window wiper set up. I've got one I'm going to use on my Model A pickup. It looks like it will fit in the windsheild header. ..........Jack
Thanks a lot this was very good ideas specially the rear window wiper As usually the ham is very helpfull
I used one out of the rear of a mercedes suv, I have a spare from a grand caravan they look Identical just the caravan doesnt have as much sweep. they have a really long shaft you just have to cut some of the plastic back. Ill get you some pictures. the only problem is its just a single speed.
