Technical wiper motors?
Discussion in 'Traditional Hot Rods' started by jerryt, Jun 8, 2024.
  1. jerryt
    jerryt
    I have a 1955 Ford F100 and im looking for a windshield wiper motor fix. I have switched over to 12 volt system and I want wipers. It doesn't rain to much in California but just in case. Does anyone know a good kit or a hack I can do?
    Thanks
    Jerry
  2. RAK
    RAK
    Newport Engineering, used them on several different vehicles and always fit and worked excellent.
    Rich
  3. F-ONE
    F-ONE
    from Alabama
    Hack......
    You can use a carburetor spring on the p***enger antenna, tie a string to the spring, loop the spring around the wiper arm, run the long end through the driver’s vent window. When it rains...... pull the string.
    Since you are in California you will not have to pull it that much.
  4. hepme
    hepme
    Can't help with a specifc name/brand, but if you can do a search and find an oem type motor that would fit your needs that's the way to go. I did a 55 chevy converted to an oem 57 electric-great. I've spent mucho dinero on "replacement" motors that truly ****. Have one on an Elco now that cost about $150. and i'm lucky to get one speed, the slowest, if it works at all. Forget the washer option that was extra, it never worked. Oh, its the 3rd one on warrenty. ‍♂️
    dirt t likes this.
  5. jerryt
    jerryt
    I am looking at a kit from mid fifties. I have bought stuff from them not much because my truck is pretty compete. I just thought that I might be able to use like a later ford wiper set up.
    Thanks
    Jerry
  6. +2. happy with mine.
    Ben
    fabricator john likes this.
  7. atch
    atch
  8. I've had better results with Newport than any of the others.
  9. RMR&C
    RMR&C
    from NW Montana
    Ford trucks went to 12v in '56. later trucks (57-66) might be similar.
    On my '51 COE I used a voltage reducer to run the 6V wiper motor on 12V. Works fine for as little as I use it.
  10. Bandit Billy
    Bandit Billy
    Another satisfied Newport customer. And their tech people are incredible!
  11. BJR
    BJR
    Look at rear wiper motors from the back window of minivans.
    dirt t, 327Eric and Speccie like this.
  12. Blue Moon Garage
    Blue Moon Garage
    I wish some smart dude would come up with a battery powered wiper for my avatar. I don't want to wire in a wiper for occasional use. I have driven in plenty of rain and RainEx works pretty well but a wiper would be nice. Battery powered, of course, can't be that difficult, can it?
  13. I went to PickNPull for the lock mechanism for the rear hatch of my '96 Explorer and thought that since the two-speed wiper motor is back there, too, why not just get it and maybe adapt it to my '29AA. Haven't followed through on that yet, but the original rear wiper motor doesn't get much use so why wouldn't the boneyard one be reliable and hardly used, too? Maybe, maybe baby!
  14. caceo
    caceo
    There was an outfit in Oregon called Raingear Wiper Systems-- they might be able to help. I know that they did systems for 55-57 Chevs
    '28phonebooth likes this.
  15. I put a Raingear kit in my '51 Chev pickup over 20 years ago.... It fit like a glove and has worked flawlessly. AT the time I purchased it, it was substantially less $$$ than Newport, and their tech guys (owners) knew their stuff.
  16. BJR
    BJR
    This is a traditional car site, lets build stuff from junk yard parts. After all that's the way we did it back in the day. :D
    30 Buford likes this.
  17. abe lugo
    abe lugo
    I drive most of my cars in LA got caught in a medium size rain on one of the project drivers with no wipers. It was not the end of the world.
    I bet you just get by with some of that RainX would get you home. One of my 57 Ford's has a Newport wipers and I just so so versus original style
  18. MMM1693
    MMM1693
  19. 29Sleeper
    29Sleeper
    from SoCal
    Drill 1 hole - add Model A Roadster wiper. No wiring necessary. Or use RainX. A-17655-AR.jpg
    cfmvw, alanp561 and abe lugo like this.
  20. jaracer
    jaracer
    With the exception of vacuum and hydraulic wipers, all the others are battery powered.
    oldsmobum and alanp561 like this.
  21. Back in the 60's and 70's when you could just go get one, I used to take the 56 Truck wiper motor off the gear box and just put it on the 53-55 gear box. That required a couple hand wrenches and soldering 2 wires on the points plate. Extremely simple change over to 12 volts. I would guess maybe the 57 to 66 units used the same basic motor. We didn't have the Visa Card or 1-800 fix back then.
    BJR likes this.
  22. Mr48chev
    Another vote for doing it right and getting a motor from Newport Engineering. Their wiper motors are as close to plug and play as you will find. I have another brand that is cable operated that required swapping out the stock linkage for the cable setup that is a royal pain in the ****.
  23. A Boner
    A Boner
  24. CME1
    CME1
    I have used several Newport Engr. wiper sets on several different cars. They install great with very little work!
    dirt t and gimpyshotrods like this.
  25. flatheadgary
    flatheadgary
    from boron,ca
    for that price they had better work great! where do you people get all that money to buy so much high priced stuff that's out there. what do you do for a living to afford these things.
    6sally6 likes this.
  26. I sell my body! (I have to buy low-priced parts though....VERY low-priced parts!)
  27. BJR
    BJR
    Are your stock wipers 6 volt or vacuum? If 6 volt just put a voltage drop on it from 12 to 6 volts. If vacuum take the vacuum motor apart and clean and lube it. It isn't like you will be using it every day.
  28. BUT!! After setting all those "days" or "months" unused they may or may not perform adequately. Mine did not. New Port to the rescue!
    Ben
  29. [​IMG]
    Being I never stop thinking I can still do that I bought this unit from C-J's Pony Parts a while back for my current 53 F-100 project. Today it's on there sight for right at $150.oo. I then removed the motor from the gear box and bolted it to my stock arm unit. It was a real No Brainer thing. Yes, it was a bit of sticker shock being they used to be $15.oo items 40 years ago. Hay, fun costs money get used to it. You just gotta add another Zero to the price of everything today from what things used to be, those days are Gone! If $150.oo kills your Wallet you might be playing the Wrong game.
    RAK likes this.
  30. Dang photo didn't follow. Go to C-J's and look at 56 F-100 wiper unit.
