Technical Wire Gauge Sizing
Discussion in 'The Hokey Ass Message Board' started by PickupNut, Sep 8, 2022.
  1. PickupNut
    PickupNut
    Any reason NOT to step up to 14 gauge wire on rear turn signals/ tail light wiring? Long run to rear of 55 Chevy step side, thought it couldn’t hurt. Stock looks like 18?
  2. Never a reason, in my opinion, for NOT using larger wire. I wired my avatar with one size larger than original on everything.
    Ben
    jaracer likes this.
  3. ekimneirbo
    ekimneirbo
    from Brooks Ky
    Should be fine, especially if you decide at a later date to add a third brake light or something else back there.
  4. 1971BB427
    1971BB427
    from Oregon
    No reason you need to, but it never hurts to run larger, except where it might not be as flexible, or space is an issue.
    firstinsteele likes this.
  5. squirrel
    14 will be fine. Bonus if you get that trailer wire that has a jacket over it, so it will take more effort to damage it...***uming you're using the truck as a truck....
  6. bobss396
    bobss396
    Wire gauge gets to be real important in aircraft due to weight. Anything that goes into a plane is considered payload. In a car, no such issues exist.
    Kelly Burns likes this.
  7. G-son
    G-son
    from Sweden
    Extra cost, extra weight, takes up more space, might not fit into connectors etc, the higher voltage reaching the lamps will reduce their life and increase brightness. Other than that, no problems.
    bobss396 likes this.
