wire wheel on axle housing?
Discussion in 'The Hokey Ass Message Board' started by 56 ford custom, Mar 29, 2013.
  1. 56 ford custom
    56 ford custom
    from Socal
    Would using a wire wheel on a small grinder be fine to clean the 9 inch in my f100? I'm cleaning to primer and paint it
  2. 53olds
    53olds
  3. sounds like a lot of work depending how clean and rust free you want it
    i'd have it sandblasted
  4. 56 ford custom
    56 ford custom
    from Socal
    Well I had the backing plates and other smaller parts blasted. I'm just going to clean the housing up as much as I can myself. I don't have a truck at the moment to have this thing taken to a shop to press everything out to have it blasted. So I'm sure it will come out well like this.
  5. HOTRODPRIMER
    HOTRODPRIMER
    Yes,,it will be time consuming but it will get the job done. HRP
  6. chubbie
    chubbie
    sure that will work, but let me remind you of the danger of wires flying off the arber at 10,000 RPM! I've pulled them out of my knee cap and stomach and other unsuspecting places!! so far not the eye!!:eek:
  7. RopeSeals???
    RopeSeals???
    Yes, and wear safety gl***es or goggles!
  8. Dane
    Dane
    from Soquel, CA
    They work great. Just keep the grinder well away from your shirt. It can grap and wrap itself into your stomach in a blink. This is what I found after unwinding the wheel from my shirt.
  9. Weedburner
    Weedburner
    from Wa State
    Sometimes i'll get housings that look like they were recovered from the ***anic. I hit them with a diamond grinding wheel (which quickly removes the hard rust without plugging up), followed by a flap wheel to smooth it out.
  10. Rusty O'Toole
    Rusty O'Toole
    It's as good a way as any. As others have pointed out, wear eye protection leather gloves and a leather apron if you have one.
  11. That's all I did with my banjo. I did the backing plates separately. Simply cleaned the whole thing up as you said and painted with a good ch***is paint. I was happy especially since mine is out there for all to see. Just be safe for when those bits of wire go flying. Go slow
  12. 56 ford custom
    56 ford custom
    from Socal
    Ill definitely use eye protection
  13. rpu28
    rpu28
    from Austin
    Get an angle grinder from Harbor Freight and one of those twisted-wire, cup-type brushes. You can throw it all away when you're done and it will still be cheaper than sandblasting. Plus, think of the fun you'll have.
  14. tommy
    tommy
    I don't care for wire wheels on angle grinders. Years ago we would use "cup brushes" on body grinders until my buddy had one slip out of his hand, grab his sweat shirt, run up his arm and smack him it the jaw. It knocked him out and fortunately it fell harmlessly to the deck and spun to a stop. I haven't used one since.
    I spent a little time removing wires from my shirt that came from my bench grinder.
    I just don't like high speed wire brushes! I use the old school hand held wire brush. When I weigh the time saved against the potential danger it's a no brainer for me. We never think about what could happen until it's too late. JMHO
  15. 56 ford custom
    56 ford custom
    from Socal
    Tommy, I do agree...They are pretty dangerous but the grinder and wire wheel is what I have and its easy and fairly cheap. I just have to be careful
  16. Wear a perspex full face shield, very heavy leather gauntlets and good overalls. Be alert to it grabbing and smacking you in the face or running across your hands/arms at all times. As mentioned, watch out for flying wires - you can position yourself in relation to the wheel so that the risk is reduced a bit. Cup brushes are better than wheels for this but tend to grab more than wheels.
    A hand brush is much, much safer but tends to skate over thicker rust. Works well if you use it in combination with 40 or 80 grit paper.
    I usually end up using a combination of grinder, flap wheel, hand wire brush (the Spid ones are cheap and effective over here and come in plain steel, br*** & stainless), s****er, different grades of paper and even a die grinder and a dremel. I used all of these on some F1 backing plates recently to get in all the nooks and crannies.
  17. 56 ford custom
    56 ford custom
    from Socal
    I had bought the same exact brush at harbor freight yesterday
    yesterdsy
  18. Don's Hot Rods
    Don's Hot Rods
    from florida
    Those little wires that fly off the wheel at high speed are like arrows. I have been showering at night after using one and will find a stray wire sticking out of my skin. Didn't even feel it going in. Just think what it would do to an eyeball. :eek: Goggles and heavy gloves are required for sure.
    Don
  19. 56 ford custom
    56 ford custom
    from Socal
    I totally agree. I had some in my shoe and got pushed into my toe
