Features * Wire Wheel only pic thread *......
Discussion in 'Traditional Hot Rods' started by 3wLarry, Aug 22, 2010.
  1. They look like GM/Chevrolet from about 1936
  2. gwhite
    gwhite
    SUPER MODERATOR
    Yup, 6-lug gives it away...I'd say 1935, as I believe Chev switched to artillery wheels in 36.
  3. Gary,
    I think you're right, but here's a '36 Master with wires to see what it'd look like:D:
  4. mow too much
    mow too much
    I love these, had a set on my 35 Ford coupe about 20 years ago, works of art...:cool::)
  5. wheelkid
    wheelkid
    Alliance Vendor
    from Fresno, CA
    Awesome picture!! Those look like a 16" 1930s chevy truck wheel. Pretty rare actually. Anyone have any similar pictures?
  6. gwhite
    gwhite
    SUPER MODERATOR
    You got me :D
  7. Autodave
    Autodave
    from Menifee,Ca
    Here's mine, I'm not sure if I should put trim rings on...
    ROCKER77 likes this.
  8. waxhead
    waxhead
    from West Oz
    my 31 pickup, I am also undecided about trim rings
  9. VA T
    VA T
    Clayton,
    Your Dad's philosophy come through loud and clear in your wonderful Model T. It will always be one of my favorites!
  10. PA2KS
    PA2KS
    OK guys, i thought i was hooked on red stealies but i have officially changed my mind to red with stainless wires....
  11. VoodooTwin
    VoodooTwin
    from Noo Yawk
    Thats a beautiful truck.
  12. Bader 2
    Bader 2
    Powder coated black7.50 and 6.00x16
  13. creepyjackalope
    creepyjackalope
  14. Jalopy Joker
    Jalopy Joker
  15. tofords
    tofords
  16. BIG-JIM
    BIG-JIM
    from CT
    I finally got mine mounted. Now I'm contemplating putting on the ribbed beauty rings.
  17. mac miller
    mac miller
    from INDY
    4rear-2.jpg TWSNov09070 2.jpg 10402749_10152481346838259_5568611256957683998_n.jpg WIRE WHEEL TECH
    The next time you encounter a vintage racing car with wire wheels
    Look at them with a little bit of respect.
    Wire wheels are very interesting and there is a lot more to the way they work than most people think.
    There were three brands of wheels that were common in US oval racing in the 20s, 30s, 40s and, even, into the 50s. The low buck option was the stock Ford, welded spoke wheels made by Kelsey-Hayes. These were a bolt on wheel..........Another brand that I have run across is the Buffalo wire wheel. They were used on 30s and 40s “big cars” They used real threaded spokes and appeared to be a quality wheel......... The “top of the line” wire wheels were the Dayton Wire Wheels made in Dayton, Ohio. This company is still in business. They were used on the Indy Cars in the 30s, 40s and into the 50s.
    Most of the good wire wheels were built on the, Euro origin, Rudge-Whitworth metric splined hub. Why? I’m not sure, unless it was from the influence of the pre WW1 euro participation at Indy. It was always a mystery to me how the most basic part of the most American type of racing used a euro metric standard component....??? Even into the 50s, some of the first magnesium wheels were built to fit on the Rudge metric splined hubs.
    There was a lot of more dynamics in a wire wheel than most people realize.
    Wire wheels have a radial, lateral and vertical spring rate and can, totally, change the handing and feel of the car depending on spoke count, length and tension.
    Ted Horn used his wire wheels for suspension tuning by having wheels with different spoke tensions and/or lace patterns for different race tracks and track conditions.
    With today's totally rigid wheels the lateral spring rate is done with different tire side wall construction.
    In the early 20s, Tommy Milton, Harry Hartz and Ira Vail had Millers that were0 sponsored by DiSteel. DiSteel made steel disc wheels.
    They used their sponsor's wheels during the Indy 500, but found the ride very harsh compared to the softer spring effect of the wire wheels.
    Another interesting effect of the early solid disc wheels or wire wheels with aero wheel covers was that when the drivers turned the front wheels into a corner, the air would catch them, like a sail, and cause the car to oversteer into the corner. For that reason the more common setup was to use the disc wheels in the rear with the wire wheels in front.
    The most common sizes of wire wheels were 15”, 16”, 18” and, even, 20” diameter.
    I have noticed that there were hardly any migets that used wire wheels.... apparently, there was nothing available in that size (12” diam).
    Some of the Euro brands of wire wheels that, probably, saw action in U.S, racing would have been Dunlop, Borranni and Campagnolo.....
    I’m sure some of the other esteemed historians of this list can come up with more detailed information than I have and I welcome them to add to this and, also, correct any misconceptions that I may have
    Generally, the more flexible the the wheel is in lateral, radial and vertical load, the softer and more forgiving the ride.
    Better handling characteristics, such as acceleration, braking and steering, require a stiffer wheel construction.
    factors effecting wire wheel dynamics and characteristics
    spokes- count
    gage
    length
    material
    tension
    radial angle of attachment
    lateral angle of attachment
    lace pattern- radial or cross lace
    structural friction
    rims- weight
    rotational inertia
    ridgidity
    material
    hubs- wieght
    rotational inertia
    ridgidity
    material
  18. Jersey Joe 67
    Jersey Joe 67
    from J Town
  19. 34dlxcoupe
    34dlxcoupe
    from Lincoln
  20. gump
    gump
  21. timwhit
    timwhit
    Larry: My pickup after I put the wires on. Tim 100_0106.JPG
    waxhead and 3wLarry like this.
  22. fordy standard
    fordy standard
    from Warren, MI
  23. robber
    robber
    cp 260.jpg ..."Wired & Tired"... :)
    waxhead likes this.
  24. Rocky
    Rocky
    Classified Editor
    Finally got my Chrysler wires powder coated and fitted the early ford caps to them. 34side1_15-0small.jpg
    mattheruthless likes this.
  25. Frankie47
    Frankie47
    from omaha ne.
  26. silent rick
    silent rick
  27. 2935ford
    2935ford
    waxhead likes this.
  28. timwhit
    timwhit
    Haven't seen this one yet. The Rollston Ford with CHROME plated 16" 35 ford wheels. rollston.jpg
  29. Gary Addcox
    Gary Addcox
    Those are very cl***y, IMHO.
  30. timwhit
    timwhit
    roadkillontheweb: Those appear to be bent spoke kelseys. I had a set once that looked like ford wheels but were a 4 1/2" bolt pattern. I always ***umed they came off a dodge or plymouth, (which is what I think you have pictured) They were 16" wheels but the center hub was a little smaller than the fords, causing the spokes to look longer. Tim
