i got space problems at the front end my 63 impala got front disc brakes from an camaro ,now i got the problem that the tires touch the fenders. have anyone the same problem and got an idea how i get some space between tires and fenders ?? thanks holzi ps: the 63 have airride and 14x7 luxor wheels with 175/75/14 on it !
A friend of mine has a 64 Impala with hydros. He's running 13's with the same reverse offset you have (reverse). What he did was use the stock upper control arm, a chevy S10 pickup spindle and modified the lower control arm to take the S10 balljoint by welding a new end on it (from a S10 lower control arm). Theoretically, you could run one of the 'unbreakable' ball joints from CCE that I think bolt in. He clears his 13's no problem, nothing got pushed out at all. Hope this helps
We make a zero offset DBK for your Chevy that will bring the wheels back to drum brake position. You can use some of the parts that you already have. 860-872-7046.
hey.. I have the same wheels on my Lincoln.. but i lost a hub cap.. can anyone tell me where i can pick one up? Thanks
