Wiring Brights threw a toggle switch???
Discussion in 'The Hokey Ass Message Board' started by jamcoupe, Mar 13, 2008.
  1. jamcoupe
    jamcoupe
    Is there a way to use a toggle switch instead of a bright light floor switch to turn on & off my brights.
    Thanks Jeff
  2. Petejoe
    Petejoe
    from Zoar, Ohio
    Sure you can.
    But if I were you I would hook up the dims and brights both on the same three position pull out headlight switch.
    First pull would be the dims, second would be the brights.
  3. Chaz
    Chaz
    Use a double pole , double throw 20 amp switch. I used one on my 33 Plym and it worked great!
  4. jamcoupe
    jamcoupe
    Is that the same as a on/off/on switch with 3 connections on the back?
  5. brokenspoke
    brokenspoke
    I use a 3 position pull switch....one out low beam..two out high beam
  6. curtiswyant
    curtiswyant
    This is what I do, too. No need for parking lights.
  7. jamcoupe
    jamcoupe
    Thanks yall! will do
  8. chaddilac
    chaddilac
    Light switches/high low floor switches are like $2.00 at the salvage, why not use one of them?
  9. revkev6
    revkev6
    from ma
    they can be REALLY hard to get to in a hot rod. got one in my model A and I look like I'm trying to stamp out a bag of dog **** every time I use it. :rolleyes:
  10. Chaz
    Chaz
    Its more of an on/on with no off in the middle.That way in case you bump it you dont go into darkness.
  11. Yeah, it's tough to fit a floor dimmer sometimes in the narrow floor of a hotrod, and it's usually up where it's hard to get your foot on it. SoCal sells those pull pull pull headlight switches so you use the one switch for your parking, low, and high, just by pulling in and out. Then you don't have to run wires down to your floor for the dimmer.
    If you want a toggle switch, you just wire the output of your headlight switch to the center "common" terminal of a SPST "On-On" 20 Amp toggle switch, then run one of the other two terminals to the highs and the other terminal to the lows.
  12. Gotgas
    Gotgas
    from DFW USA
    I sure hope you plan to use the toggle switch to power a relay, instead of having all your headlight current p***ing through it.
  13. zzford
    zzford
    I have a GM column in my car. I bought an aftermarket tilt lever with a "momentary on" switch on it. I then wired my h'lights through a VW headlight relay. Touch the ****on on the tilt lever, shazzam, as if by magic, the headlights go from high to low!!!
  14. eisenhower34
    eisenhower34
    PM me and tell me what you are using for a Toggle Switch. Do not use the cheap Chinese **** that is out there. I work for Honeywell and we make some military grade toggles. Let me know what you are looking for....I'm sure I can find something that will far exceed what is out there that followed me home from work (I have boxes of these high end switches)
    Ike
  15. rustyford40
    rustyford40
    from Mass Bay
    I put my dimmer under the dash so I can hit it with my hand.
  16. krusty40
    krusty40
    On my former '27 tub, I used a push****on velcroed to one of the steering wheel spokes to energize a relay under the dash. I could unplug the push****on and stash it during daylight driving. vic
  17. rustyford40
    rustyford40
    from Mass Bay
    If you use a toggle use a relay with it so you don't burn out the switch.
  18. AnimalAin
    AnimalAin
    Most relays have two power paths through them, normally open, and normally closed. If you set up the low beam to the normally closed circuit, and the high beam to the normally open circuit, you can go from low to high by simply powering the relay. Operate the whole deal with a power switch (lights on/off), a control switch (lights hi/low), a relay, and some wire. Added advantage of default to the low beam, as well.
  19. jamcoupe
    jamcoupe
    I got a 2 pull light switch this weekend.
    If I wire my lowbeams to the parking lights terminal and my
    highbeams to the headlight terminal is that ok. It has a fuse on the switch itself do I need a realy.
  20. Petejoe
    Petejoe
    from Zoar, Ohio
    No relay is needed. I hate relays. I have had more of those go bad than switches. I understand during high amp loads they are needed but the headlights won't pull that much. I never use them and have never had a problem with any hookups over decades of use.
