Technical Wiring / Circuit Connectors??? Help.
Discussion in 'The Hokey Ass Message Board' started by therocket88, Aug 16, 2015.
  1. therocket88
    therocket88
    This may be a stupid question, but electrical is not my strong suit...
    I'm trying to complete a circuit without using the front turn signal sockets. Is there a connector or a way to bridge the circuit without the socket? Like a temporary connector?
    History- In order for my brake lights and rear turn signals to work, the front lights must be wired as well. I just removed my front bumper to have it plated, therefore there is no bracket to mount the front lights temporarily. I need to drive the car about 50 miles and need brake lights.
    Is there an easy solution to this?
    Thanks!
  2. Your brake lights should have nothing to do with the front turn lights....
  3. squirrel
    It's possible that you need the front turn signal bulbs in the circuit, to make the rear turn signals blink.
    Since you don't have front turn signals, I doubt it's going to be much of a problem, not having rear turn signals.
    Like he said, the front has nothing to do with the brake lights working.
  4. David Gersic
    David Gersic
    from DeKalb, IL
    I'd like to see how this is wired, because that shouldn't be true. But,****uming it is, how about just zip tying the front signals to something nearby and calling it good enough? Or make a couple of temporary brackets that fit on the bumper mounting points to hold them?
  5. Davyj
    Davyj
    I am guessing that your turn signals do not blink........that is due to a low load without the front lights......quick fix, slap in an electronic flasher that does not use load...........
