Wiring experts help needed~
Discussion in 'The Hokey Ass Message Board' started by Adam F, Nov 18, 2003.
  1. Adam F
    Adam F
    Hey everyone,
    I've got a single speed windscreen wiper unit that does about 45 cycles per min. To get my rod registered, I must have wipers that will do 25 and 45 cpm.
    I have seen a two speed switch but can't locate one locally... any other ideas??
    Adam F
  2. shoebox72
    shoebox72
    Maybe you can run it thru a rheostat, like on a headlight switch to dim the instrument panel lights. You may be able to temporaraly run them thru a headlight switch to get them to go slower so you can get your car registered.
    Maybe a blower motor switch works the same way.
    Billy
  3. Crease
    Crease
    Rheostat or just a resistor. Should be able to put one in series. If you wanted to you could add a switch that bypasses the rheostat, which would give you 2 speeds.
  4. Hi, no experts here but a thought or two. The rheostat may work, the blower switch usually has a variable resistor. If you have a look at one,(like a 70-80 chevy), youll see three different sized coils that represent the three speeds. Each offers up different resistance to make different voltage to the motor. My suggestion is a mid 60's GM or Ford 2speed wiper motor, and switch if necessary. I think if you were to use a headlight switch, it'll work for the inspection, but may burn up the motor or the wiring when you need to use it. The old amp draw deal. Good luck.
  5. Adam....I just did this conversion on my coupe man. Email me at charga770@hotmail.com and Ill give ya the drum on whats involved OK!!
    Rat [​IMG]
