Wiring harness question
Discussion in 'The Hokey Ass Message Board' started by HILLBILLY HOT RODS, Jan 21, 2014.
  1. HILLBILLY HOT RODS
    HILLBILLY HOT RODS
    I'm looking into getting a wiring harness for my 39 Desoto coupe any suggestions on brand and how many circuit I will be running
    - headlights
    -brake lights
    -running lights
    -signal lights
    -power windows
    -elec fan
    -elec fuel pump
    -wipers
    I would like to keep it as inexpensive as possible not trying to be a cheap ass but I would like to keep it on the cheap but works decent.
    Thanks
  2. 327-365hp
    327-365hp
    from Mass
  3. ryno
    ryno
    call bob at rebel. hes top notch
  4. Hear we go again. Just call Rebel. He is on the HAMB.
  5. The37Kid
    The37Kid
  6. If you want cheap, Speedway has some cheaper than a lot of name brands. But I couldn't say if they are any good or not.
  7. The37Kid
    The37Kid
    Hope that wasn't directed at me, anything that will burn your car to the ground is something that deserves the most respect, and top shelf components. Bob
  8. creepjohnny
    creepjohnny
    Another for rebel wire!!!!
  9. Nope, not directed at you are even at Speedway. I just saw in their catalog that their wiring harnesses were more inexpensive than others that I have seen.
  10. sobpunx
    sobpunx
    I put a speedway in the 54 over thanksgiving without a problem.
  11. d2_willys
    d2_willys
    from Kansas
  12. primerhotrod
    primerhotrod
    from ILLINOIS
    American Auto Wire, makes some great harnesses. I have installed quite a few. I am not sure if they cover your application, but they may have something that will cover your needs.
  13. JeffB2
    JeffB2
    from Phoenix,AZ
    Rebel 9+3 would be right up your alley. http://www.rebelwire.com/ Tell Bob the HAMB sent Ya! With the circuits you are adding read the section : "A current topic" here: http://www.watsons-streetworks.com/tips DO add the HD relay on the ignition switch,also with most headlights being Halogen the relays added there are a big plus so you get the brightness you want.
