wiring headlight switch rebel harness
Discussion in 'The Hokey Ass Message Board' started by rick3658, Jun 8, 2013.
  1. rick3658
    rick3658
    from wisconsin
    need to get parking light to work I not sure there is power coming out the switch for them...... Right now the only way I can get them to work is by hooking them to low beams and the you cannot see them flash. I am using a gm switch from late 70 gm. would i be any better off buying a after market switch. also dont seem to be able to power gauge light or dim them. thank
  2. themoose
    themoose
    Sounds like you have the signal light filament hooked to the light switch instead of the part(dim,small filament) I'm sure you already have a diagram and I'm not sure yours is like the one in the link below from another post on HAMB but it might help.....
    http://www.jalopyjournal.com/forum/showthread.php?t=697147
    Also here is a GM light switch diagram
  3. rick3658
    rick3658
    from wisconsin
    that helps some but my wires are from rebel wire fuse box and colors do not match this
  4. 325w
    325w
    Maybe match the writing on your wires to the terminals with the same name as on the switch.
  5. 24riverview
    24riverview
    GM headlight switches of that vintage require 2 power feeds, one unfused that powers the headlight circuit breaker that's built in to the switch, another fused wire that powers everything else. Never used a Rebel but the last harness I installed wanted you to put jumper between the two power terminals, I changed it to the way GM wanted it but what I'm saying is check that you have the two power feeds to the switch. If I was home I could post a diagram.
  6. jcapps
    jcapps
    from SoCal
    I second the jumper. AAW has it in the harness already but some require you to add it. Re check the directions
