Hot Rods Wiring Help Needed
Discussion in 'The Hokey Ass Message Board' started by 1oldhotrodder, May 19, 2019.
  1. 1oldhotrodder
    1oldhotrodder
    I am wiring a '46 ford. 351w, 60's Ford alternator, regulator, rear mounted solenoid, and battery. Instead of running another wire from the I terminal on the solenoid for a full 12
    volts while cranking, can't I just run a wire to the starter post. That would send 12 volts
    while cranking, it seems that would be the same as a separate wire. Please, no guessing.
  2. squirrel
    problem is when the engine starts, you keep providing power to the starter through that wire, from the ignition circuit.
    there's a reason they did it the way they did it.
    Boneyard51 likes this.
  3. 1oldhotrodder
    1oldhotrodder
  4. 1oldhotrodder
    1oldhotrodder
    That makes sense. Thanks
