Wiring Help!
Discussion in 'The Hokey Ass Message Board' started by tfeverfred, Apr 13, 2008.
  1. tfeverfred
    tfeverfred
    Okay, I'm wiring my car myself and NOT using a kit. I'm done, except for one small problem. My car won't shut off when I turn the key off!:eek: I have a HEI system with a 3 wire alternator. Speedway sells a little wire piece that looks like this to sovlve the problem:
    Does anyone know away around this problem without giving Speedway $18.00 for a hunk of wire and what is probably a diode?
    Please help. I got everything done and this is the last thing I need to do. Thanks.
  2. Flat Ernie
    Flat Ernie
    Tech Editor
    Put your own diode in your power line.
  3. Fogger
    Fogger
    You do need a diode to stop the reverse feed from the alternator. You can find them at Radio Shack. A friend used two connections on a bridge rectifier to accomplish stopping the output of the alternator to the ignition. On the diode the lead with the band stops the flow. The FOGGER
  4. tfeverfred
    tfeverfred
    What voltage rating does it need to be? And is it actually a diode in their? I was just guessing.
  5. TooMany2count
    TooMany2count
    from Cahokia,IL
    I bought a one way diode at Radio Shack and from the Painless Wiring website
    To correct the run on problem you need to go to your local Radio Shack and buy part number 276-1661. It comes in a pack of 4 diodes for about $2.75, but you will only use one. The diode will go inline in the Exciter wire (#914). The body of the diode should have a stripe on one end. The stripe needs to point towards the alternator. The diode is a one way electrical valve that will not allow the alternator to feedback to the ignition system when you turn the key off.
  6. tfeverfred
    tfeverfred
    Thanks, I'll give it a shot!
  7. tfeverfred
    tfeverfred
    That was it!:) I wired my without a kit and I am STOKED!
  8. I spoke with Dirty2 at the RoundUp & he told me to run the #2 terminal directly to the charge post, then on to the Battery, to charge.
    Take the #1 terminal directly to the ignition switch, so when the switch is turned off, it kills the feed from the alternator.
    Surely, you don't have the #1 terminal run to your col, do you?
    More than likely, not.
    All of this is run on my truck w/ an internal resisted 12V coil & a '53 Flatty.
  9. swimeasy
    swimeasy
    Fred, you just are about the best problem solver that I have ever seen! CONGRATZ!
  10. did you run the wire going to the distributor to the ignition terminal of the ignition switch , and that's the only wire on that terminal like i said in another post?
    i don't think so.............
    why do i bother
    the diode works too...but put the wire that excites the alternator on the accessory side of the ignition switch and you don't need it
  11. butch27
    butch27
    Way to go Fred!!
  12. maxspeedracing
    maxspeedracing
    In the photo, the red wire is normally just folded over and attached to the Bat terminal of the alternator. Rather than a diode on the yellow wire, you can use a 12 volt light to act as an idiot light, and this has never given me a problem with run-on.
    The red wire can also be run all the way to fuse box. As I understand it, this is the better way to go on a high current system. If you have, say, a Buick Riviera with four electric windows, a computer, a DVD player, electric seats, doors and trunks, and a 800 watt boom box, then run this wire all the way to the fuse box.
    The red wire should be a #10 minimum.
  13. d2_willys
    d2_willys
    from Kansas
    I agree, u don't need the diode at all if you wire the excitation terminal to the accessory terminal.:D
    I can't believe that there are people out there buying those $18 wires when you don't need it at all. Even more incredible is that there are people out there selling those stupid things.:eek:
  14. jerry
    jerry
    You can do they same thing with a 2 wire lamp socket and a small light bulb. Just wire it in series with your exciter wire going to your ignition switch. Place the bulb anywhere along the circuit and it will prevent the run on. Gives a glow when you shut off the motor and when you turn on the ignition, just like the traditional generator light in a traditional wiring system.
    jerry
  15. tfeverfred
    tfeverfred
    Thanks again for all the advise, but the diode was only $2.99 and I got four of them. The other solutions were good too and I'll keep them for future reference.
  16. hmmm everyone trying to not use a charge light and here i am trying to put one in (po installed a 1 wire alt). you can use a diode but then you won't know your screwed until it shuts off and won't turn over again.
  17. tfeverfred
    tfeverfred
    Yes 36, that's how I did it and that was the first thing I checked. I'm not sure why it didn't work I'm NOT an electrician, but I'm pretty good at following directions. I thank you for your help.
  18. 325w
    325w
    Some times when we use the real high amp alts. electric fans and sometimes small fuse boxes we get an over run. Not sure why. On the tri 5's we use the diode trick most everytime. Most times we use the new Damjunk switches we have the problem ???? IMO..
  19. Flat Ernie
    Flat Ernie
    Tech Editor
    I've seen fans act as generators as they spin down once power is shut off...usually only a problem if they're on the same exact circuit as the ignition...
