Wiring hot rod question
Discussion in 'The Hokey Ass Message Board' started by AMC360, Mar 12, 2012.
  1. AMC360
    AMC360
    from Canada
    I am wiring my car from scratch, I have a wiring diagram almost ready to go but I need help with one little thing. I am running a flathead with a Procomp ignition box, I have a 4 terminal starter selinoid and I will be using a key switch and a push button starter.
    I have 12v power to both switches.
    My question is the push button starter switch, what terminal on the selinoid should it go to, the S or I terminal. Also since I am using an ignition box that supplies everything to the coil and distributor, do I need anthing connected to the other selinoid terminal?
  2. the s terminal, and no you do not need to hook the i terminal up.
  3. 12 volts into the S terminal will engage the starter solenoid.
    You will have 12 volts out of the I terminal only while cranking. Used for ignition systems that require 12 volts start, 9 volts run.
  4. AMC360
    AMC360
    from Canada
    Just what I wonted to hear, thank you.
