wiring kit question
Discussion in 'The Hokey Ass Message Board' started by shocker998md, Jan 8, 2012.
  1. shocker998md
    shocker998md
    Quick questions guys,
    I have a 1966 F100 and in the next year or so I want to re wire it. Looking at the Rebel kits and the EZ kits im not sure about one thing. Is wiring included for under the dash? As in the ignition, heater, wipers, and then the lighting for the cluster? I havent been able to get an answer from just reading the discription of the kits.
    thanks for any input guys.
  2. 210sedan
    210sedan
    from upnorth,wi
    all there,used a rebel kit last winter in a 36 ford,was pleased
  3. All the wiring you ask about is included. Also we have a seperate guage harness that allows you to wire your guage panel out of the vehicle and then you just connect one plug once the panel is installed. VERY HANDY! Todd
  4. 1950ChevySuburban
    1950ChevySuburban
    from Tucson AZ
    You will have to provide the wiring between wiper switch and wiper motor - typically 3 wires. Also, grounds are not included, so grab a roll of black wire.
  5. larryj
    larryj
    from Madison AL
    All the wires are there in the EZ wire kit as well. They also provide a few connectors for a GM column, but plan on providing your own connectors for everything else or a non GM column.
    I have used two and they are fine if you know what you are doing. A newby may have some trouble as the instructions aren't exactly clear and detailed.
  6. Kiwi 4d
    Kiwi 4d
    we used a basic Rebel wire kit in our 32 and for the price they cant be beat. Heck its a hot rod so sure there will still be some small changes required to suit your particular ride.
  7. vtwhead
    vtwhead
    Just finished installing a 20 kit from Rebel. Well done, no issues. I opted to do my own gauge harness and plug kit. I added one more fusible link to the wiring as well. Ended up with one from the alt to the starter and one from the starter to the main + wire that feeds the rebel system.
  8. I have done the EZ wiring once and have another for my truck, everything you asked about is there and was a snap to install, I had one installation question and their tech line answered it immediatly.
  9. Lee_ATx
    Lee_ATx
    I've put in 3 Rebel Wire kits. Good stuff and good folks.
  10. shocker998md
    shocker998md
    alrighty thats what i needed to hear. I was mainly worried about rigging up a setup for the lights for the dash and all. Thanks guys.
  11. shocker998md
    shocker998md
    You guys will definatly be seeing my buisness in the future. My plan is to do this next fall.
