wiring please help
Discussion in 'The Hokey Ass Message Board' started by classiccarman, May 29, 2013.
  1. classiccarman
    classiccarman
    I'm trying to get my 1949 GMC wired it has a 1980's colum in it. I pluged everything up to the steering coulm as the kit says. All I'm trying to do is make it start with the key. I'm getting 12 volts to the big wired on the starter but no where elce. What do yoy thibk the problem is
  2. davidbistolas
    davidbistolas
    Hmm. how big is this box I'm holding here?
    who's kit are you using, and have you talked to them? What's the column out of?
  3. Normal Norman
    Normal Norman
    from Goshen IN.
    Do you have 12 volts going to the key switch? N.N.
  4. waldo53
    waldo53
    from ID
    Sounds like maybe something's missing here. There should be a wire that takes off from that same starter terminal that's hot and goes to a distribution block, or fuse panel. There are several circuits that are hot all the time - lights, horn, brake lights, and ignition switch. If your kit came with a wiring diagram, get a 12V trouble light, or volt meter and start following that hot lead to see if it's connected to the right place.
  5. d2_willys
    d2_willys
    from Kansas
    As mentioned above, there are several areas to be tested. Don't forget to look at the neutral safety wires too.
  6. damagedduck
    damagedduck
    from Greeley Co
  7. stevechaos13
    stevechaos13
    Too sp**** a question man.
    A word of advice though; when using any aftermarket wiring harness and existing wiring or hardware it is always a good idea to have the wiring schematics for the hardware and the original wiring handy as well.
    You've got to remember that with an old vehicle there is a pretty good chance that someone else has screwed with that wiring in the past and that the color codes might not match up.
    When I'm doing an ignition switch I always start out by finding the hot in and then locate the outs with a test light.
  8. HOTRODPRIMER
    HOTRODPRIMER
    A open question without much information,,we can only speculate. HRP
  9. Mr48chev
    Ok, the first thing you need if you don't have one is the wiring diagram for a 80 something GM column mounted ignition switch to make sure you have the color coding right.
    Here is the wiring diagram from and 80 Chevelle ignition switch which should be the same as almost all GM cars for several years [​IMG]
    You should be able to tell which pin and what color of wire does what on the switch by checking it.
  10. classiccarman
    classiccarman
    The kit is from ez wiring. I used a test light and im getting power no where not even to the horn. I guess im missing a wire on the starter.
