Wiring question. Is this acceptable?
Discussion in 'The Hokey Ass Message Board' started by Tugmaster, Jun 27, 2009.
  1. I am getting ready to wire my car (50 Chevy) I am running the stock instrument cluster but the only thing in it I'm going to use is the speedo.
    I have seperate guages under the dash. So, I have all these different hot and ground wires to hook up all the different guages and lights along with the ground wires for them also.
    Can I use a bus bar like this and hook up the hot wires on one side and the grounds on the other?
    http://www.defender.com/product.jsp?path=-1|328|49758|112306|299259&id=51737
    It makes sense to me and would make things a little neater under the dash. I would obviuosly hook a coomon hot from the panel to one side and a body/ch***is ground to the other.
    Please keep in mind that I know nothing about wiring and I want to do the correctly. Thanks, Todd
  2. The37Kid
    The37Kid
    Good luck, now you'll have to sort through all the conflicting electrical advice.
  3. God I hope not. This is confusing enough without opposite opinions on the same topic. It make sense to me but I know jack **** about wiring and don't want to fry anything.
  4. shoprat
    shoprat
    from Orange, CA
    I used a buss bar for the hot feeds and grounded them to a different spot
  5. Look into some wiring kits I have used Ron Francis comes with fuse box & enough color coded wire to go from head lights to tail lights There are many CO.s that make them to match what ever your building
  6. The37Kid
    The37Kid
    You know far more than I do.:)
  7. squirrel
    Well....it's one way to do it....not how I would do it, but it would probably work, and if it makes it easier for you to understand (and increases the odds of you making it work) then it could be a good way to go.
    I'm leery of having an exposed metal part with 12v on it under the dash, where it could accidently get shorted to ground (I have experience that this will probably happen)
    Also do you really need two hot busses? one for dash lights and one for ignition power? or do you plan to just run the gage lights off of ignition power? also what kind of gages are you using that you'll need more than a couple hot wires? Hopefully not an electric oil pressure gage (especially one of those chinese ones)
  8. squirrel
    Barrier terminal strips are not busses....they can be bridged, but it's not really the same thing. The terminals are connected in pairs, not along each side.
  9. Squirrel,
    I'm running Autometer Tradional Chrome guages. My intention was to run my hot wire from the light switch to the buss barr and use the buss bar to power up my quage lights along with the backlight to the original instrument cluster. I was going to use the ground side of the bus bar for the grounding of the guagelights and my guages. Yes I am using a electric oil pressure guage, Autometer. Todd
  10. Bettlejuice
    Bettlejuice
    from WV
    Personally, I would not use something like that, the terminal screws are bare, and you never want a +12 terminal open, never know what can happen and short them out. Personally, I'd just solder the connections to one common wire for the + and the - and use heat shrink and/or electrical tape to protect it. Then you could either solder the wires into the correct locations, or use a some sort of a 2 terminal male/female connector if you want to make it removable. I just don't like open 12V terminals in a car, with the vibrations you never know what could happen. (I don't even use them for stereo equipment, even if thats how it came, everything is protected).
  11. tommy
    tommy
    I'm with squirrel. Your idea will work but to me you have added a bunch of wires running to the buss along with additional uninsulated potential shorts.
    I've always just run one hot wire to the closest gauge and then make jumpers from gauge to gauge to gauge. The same thing for the grounds and the lamp circuit. I think it's cleaner that way. JMHO
    lamp circuit for under the dash gauges.
  12. That makes good sense. they do make protective covers for these bus bars but the jumper method might be even easier. Glad I asked. VIVA LA HAMB!!! Todd
  13. torchmann
    torchmann
    from Omaha, Ne
    Thats the way to do it...SANO
    all running illumination is usually off 1 fuse. your running lights go out and the dash lights go out.
    instrumentation runs from it's own fuse
    accessory lights like dome and underhood have their own fuse
    heater on it's own
    stop and turn signal is on it's own because the turn signal/emergency flasher system bridges the turn signals and brake lights through the turn signal switch
    radio on it's own
    ignition and all engine power off the switch
    the less you have unfused and unswitched the better
    You can run all your direct wired power(except for the starter) through a commercial solenoid designed for any semi truck. they have ALL power through a solenoid that powers everything off from the ignition switch and relays for the headlights and other high amp circuits. research the wiring scematic for your components and design your own harness. it should have mounting points for components and a fuse block and look like a single root-like structure when it's done
  14. lolife
    lolife
    And you don't need big wire either. I used some #12 wire on my dash, and after I was done, there was just too much wire back there and it looked like a mess.
    I had to do it over, and I think it is #16 wire if my memory is any good.
    I space my splices out. Don't try to twist four or five wires to the same point. Go a couple inches to the next Y (rosin-core solder and heat-shrink).
  15. 5window
    5window
    You always want to match your current pull to the gauge of the wire as well as remembering that for long runs of wire you may need a larger (smaller number) gauge. here's a very good site:
    http://www.powerstream.com/Wire_Size.htm
  16. squirrel
    And it's important to make sure that each wire is protected by an appropriate size fuse.....
  17. Is it "safe" to use the bus bar for the grounds? Or should I just jumper them together too? Todd
  18. squirrel
    Ground would be ok, since the rest of the car is ground.
  19. Mr48chev
    That particular unit is used on a boat for a couple or reasons.
    1. on a boat all ground circuits have to go back to the battery to prevent electrolysis plus many boats are made of non conducting materal anyhow.
    On my sailboat I use the bussbar to feed the circuit breakers for the individual circuits. I also have a separate bussbar for the ground circuits.
    the unit you showed would probably be used where there was limited space to put two units and would simplify wiring somewhat. It might also be used where you had several lights on one breaker and the bar feeding off the breaker for interior or running lights = one of those bars for each breaker that feeds several circuits.
    The next time you are in Borders or one of the other bookstores check the boat stuff shelf and see if there is a copy of one of the 12 V marine electrical books there. It will explain what I was trying to say complete with photos/drawings. Normally in a steel bodied car the sheet metal serves as the ground return with a ground strap from the battery to the body to complete the circuit.
  20. Bettlejuice
    Bettlejuice
    from WV
    Gauges don't draw much power at all, and since we're talking about pretty short runs, 16AWG will be more than sufficent.
    Those bus bars are actually REALLY handy on the ground side (again, for car audio, I've made them, we have BIG*** bus bars at work, I'll cut a couple inches off and drill and tap the holes and mount it straight to the floor pan). Just a little to nerve racking to use it on the 12V side.
    My EZ harness used all 16AWG for all the gauges. Everything in the kit was at least the appropriate size, if not larger.
  21. For what it's woth I already have a harness. I'm going to use a Rebel 9+3. I'm not quite ready for the wiring yet but I'm trying to get these questions that I have in my head figured out before I start the actual wiring. Todd
  22. Bettlejuice
    Bettlejuice
    from WV
    You're good to go then, the aftermarket harnesses have wires for the senders, and a single gauge power, gauge lights and ground wire (at least mine did, but I bought it before I joined the site and knew about the Rebels). I just sat with my gauge panel at the kitchen table, wired all the lights, grounds, and 12+ together there, that way when I went to put it in the car, I just had two wires to connect (and like I said, if you want it to be REAL easy, get a 3-pronged automotive plug and that way you can just plug it in, and unplug it if you ever need to. Actually, if you were to get a 8 pronged plug, you could even include the sender wires into the mix and make it REAL foolproof!
    You're doin' right to plan. It makes it 1000x easier. The parts of mine I didn't have mapped out before I dove in was a pain in the ***. Can't overdo the planning, I sat with a schematic of the car, the list of wire colors in the harness, and made a list of what wire in the harness would go to which wire (including color off the schematic) in the car. SUPER easy, that way you don't have to be thinkin' this **** up on the fly.
  23. torchmann
    torchmann
    from Omaha, Ne
    never never NEVER Never never never reach up under the dash with bare hands in a panic to jerk out smoking wires:eek::eek::eek::eek::mad::eek::(
  24. Sergeant_at_Arms
    Sergeant_at_Arms
    from Tampa, FL
    If you run something like this, I would suggest making a few spacers from a non-conductive tube and place a non-conductive cover over the bus held down by the screws to prevent accidental contact. This is what a lot of the high voltage equipment I work on has. Very simple, cheap, and functional.
    Hope my poor drawing helps!
      9.1 KB
  25. Bash'n'Weld
    Bash'n'Weld
    Nice one, make sure you take lots of step-by-step photos and post a thread on here, coz I'm going to be doing exactly the same with my sons 52(although the wiring date keeps getting further away:p) and we've got a 9+3 as well.
    Cheers.
  26. tommy
    tommy
    I did!:D I burnt the **** out of my hand but the truck did not burn down. My hand healed up nicely. Sometimes you have to do what you have to do to save your ride.:D I don't have to worry about it happening again...I install a fuseable link in the alternator wire ever since that happened.
    I made a choice...a burnt hand or my ride burning to the ground. I did the right thing.:D
