Technical Wiring suggestions
Discussion in 'The Hokey Ass Message Board' started by nochop, Jul 1, 2022.
  1. nochop
    nochop
    from norcal
    I’m thinking about it actually
    firstinsteele and The37Kid like this.
  2. BamaMav
    BamaMav
    from Berry, AL
    Try lubing the wires with WD40 or maybe dish soap. Should make them easier to pull, but any sharp edges could still cut them.
  3. twenty8
    twenty8
    I agree with this ^^^, especially the bit I have highlighted red.
    Do a search on "Ribbon cable wiring". If you are running carpet this will be the answer.
  4. nochop
    nochop
    from norcal
    I’ve pulled a lot of wire in the past and it sure felt as I was pulling over a sharp edge or screw. The pull string was a little fuzzy too
  5. bobss396
    bobss396
    I got some of my extra wire at Advance Auto Parts and it worked out well, good quality stuff. I also bought some in bulk from The Wiring Depot.
    https://www.wiringdepot.com/
  6. Blake 27
    Blake 27
    Wiring clamps don't need to be complicated, thin stainless or aluminum can be bent to shape to fill your needs. DSC06138.JPG DSC06172.JPG DSC02365-001.JPG
    C69A, nochop, twenty8 and 2 others like this.
  7. nochop
    nochop
    from norcal
    firstinsteele likes this.
  8. Speedway Motors sells a good wiring harness in 2 or 3 sizes for around $130 +- .
  9. nochop
    nochop
    from norcal
    427 sleeper likes this.
  10. the oil soup
    the oil soup
    from Tucson,AZ
  11. nochop
    nochop
    from norcal
  12. 427 sleeper
    427 sleeper
    If it can't be figured out here, a****st friend's, it can't be figured out at all! ;)
    nochop and The37Kid like this.
  13. nochop
    nochop
    from norcal
    I think I probably had it figured out, but you guys offered some great advice. It’s all about the details, and there are some awesome ones offered up here.
  14. Inside the car. Don't run them in a tube they can rub together and short out.
    nochop likes this.
