Hi All. I am building a '46 ford and want to install aftermarket parking Lights/Turn signals. New American Autowire 21 cir. Harness. The aftermarket lights have a dual-filiment bulb, but only 2 wires (One red, one brown). I have a hot lead for parking lights and a hot lead for the parking light, plus a ground. How do i wire this so that the lights can be used for both, if possible? many thanks in advance for any advice, charly9g!
on the lamp,one wire for the turn signal, one wire for park lights,lamp grounds through the socket ***uming its made of metal
i'm doing a re-wire right now too using the american autowire set. d-rod is correct up there... since my car is over 60 years old i wanted to make sure i had good grounds and went to the parts store and bought new sockets. on the socket there is a plug for a ground wire. i cut a 6" piece of wire plugged it in there and grounded the other end to a screw on the back side of the grill.. worked great
do your self a favor and run some heavy grounds at front of body to ft. of frame, and also at rear. you can never have enuff grounds on an old car.
