Hot Rods Wishbone ball cap question
Discussion in 'The Hokey Ass Message Board' started by Tim, Nov 18, 2016.
  1. Tim
    Tim
    from KCMO
    hey guys,
    Working on a project and havnt got some of the parts in hand and thought you may be able to help me.
    I'm wanting some measurements from a ford wishbone ball socket/cover/ clam shell/cap
    Not sure what to call it, a turtle? Lol
    This thing
    We on the same page now?
    I'm needing the size of the holes the bolts go threw and how far apart they are from each other.
    I'm building a bracket to locate the end of the wishbone with a notch for the ball and two holes to mount a shell on either side of the ball.
    Clear as mud?
    I'm thinking they are probably a pretty standard part from A to 48. But just in case if you happen to know what the one your holding came off of include that as well.
  2. Bruce Lancaster
    Bruce Lancaster
    A was small, worked steel to steel with oiling from rear main leakage. '32-48 have a rubber ball over the steel ball, pretty sure there are two sizes with larger after maybe '41 or so...
    Tim likes this.
  3. Tim
    Tim
    from KCMO
    Good to know!
    My wishbone is a 46-8 so I guess I'll need the measurement of the larger variety. Thanks Bruce!
  4. Relic Stew
    Relic Stew
    from Wisconsin
    Radius rod ball cap. '32-'40 and '41-'48 are the 2 different sized rubber covered ones.
  5. Bruce Lancaster
    Bruce Lancaster
    I've always liked the simple, direct design on the A...put it under the #3 main and it's oiled regularly with no work! The leak also kept that cotter pin at the bottom from rusting...
  6. Tim
    Tim
    from KCMO
    Radius rod ball cap, that's a mouth full lol. 41-48 is what I need
  7. BamaMav
    BamaMav
    from Berry, AL
    And if you spot one that is thicker at the bolt holes, it's a Lincoln. When I dropped the bone on my 47 Lincoln, I bought a 41-48 Ford cup like pictured above, I used it on the top, and used my original Lincoln one on the bottom.
  8. Tim
    Tim
    from KCMO
    good to know! Learn something new every day about old ford stuff :)
    Quick bump to the top for the afterwork crowd :)
  9. Tim
    Tim
    from KCMO
    Alright decided to search eBay and found this photo on what he describes as a 41-6 ball cap.
    Anyone care to confirm so we're sure this is the the right measurement for that year? Figure if it's posted the next time someone has such a silly question they'll find the answer ;)
    dana barlow likes this.
  10. KoolKat-57
    KoolKat-57
    from Dublin, OH
    From the ***le of the thread I thought you were looking for a hat with Wish Bone Salad dressing on it!
    I'm glad I read the thread, I learned something in the process!
    KK
  11. Tim
    Tim
    from KCMO
    Lol now I have to google wishbone salad dressing
  12. KoolKat-57
    KoolKat-57
    from Dublin, OH
    Here ya go.... upload_2016-11-18_20-34-49.png KK
  13. Tim
    Tim
    from KCMO
    Hmm guess the top shape of the bottle is kinda wishbone shaped lol
  14. BamaMav
    BamaMav
    from Berry, AL
    Tim, here you can see the difference in the Lincoln and Ford ball caps, Lincoln on top
    This was my first attempt at a ball drop. It worked for a while, but was too thin of material, eventually broke. My second try used thicker steel, has held up good so far.
  15. Tim
    Tim
    from KCMO
    Holy cow! That's way thicker!
  16. Matt Spencer
    Matt Spencer
    3" center to center on 1932
