Technical Wishbone ball rubber
Discussion in 'The Hokey Ass Message Board' started by alanp561, Apr 23, 2023.
  1. alanp561
    alanp561
    I've tried heating the rubber up in boiling water, lubing the ball with dish soap, nothing seems to work. How do I get the new rubber on the ball?
  2. AVater
    AVater
    IIRC, I think I might have used some K-Y. But if the soapy water didn’t work…..
    alanp561 likes this.
  3. Mac VP
    Mac VP
    Sure you’re trying the correct bushing? The 32-40 rubber bushing is smaller in diameter than the 41-48 bushing. You’d have a hard time trying to force it over the 41-48 ball. Just checking……
  4. Glenn Thoreson
    Glenn Thoreson
    from SW Wyoming
    Yes, those things can be tough. Shine up the ball with 320 wet or dry paper. See if you can get the rubber to roll back over some to make the opening a little bigger. Lube the hell out of it and the ball, Push it on really hard while twisting it back and forth. I have had some better luck with using "No Drip" type silicone grease as used for electric motors. If nothing works, try to get a tail pipe expander tool into it and crank it down to expand it. Let it sit overnight and quickly try getting it on before it loses it's temporary set.
  5. alanp561
    alanp561
    I found a post on the Ford Barn where a fellow said he lubed the ball, stuck the bushing on as tight as he could and then shoved a blowgun into the little hole and hit the air. He said the bushing went right on. Haven't tried that yet. Can't locate my blowgun. I think @Mac VP has it right, though. I've probably got the wrong bushing.
  6. '29 Gizmo
    '29 Gizmo
    from UK
    32-40 are a smooth ball, 41-48 have external ribs moulded in the rubber and are a different ball size
    Tim, Dooley, WhyW8 and 1 other person like this.
  7. Lloyd's paint & glass
    Now it's a party! We're talking about Alan's ball !!!
    theHIGHLANDER and alanp561 like this.
  8. alanp561
    alanp561
    Yeah, looks like this. That's what I've got
  9. Lloyd's paint & glass
    Hey big guy, if you need me to, I'll drive down and hold your purse while you fight with it? :p:D that looks ribbed to me. I've got a couple of used ones in the tool box from like a 47-48, and they're ribbed. Is the ball on the wishbone smooth?
  10. alanp561
    alanp561
    ballS, get it right, dammit. Speaking of which, do you and your band know the tune and all the words to "One Ball Johnny"? I'm gonna request that in October.
  11. Lloyd's paint & glass
    No sir, but you can bet we'll have it down for you :D
  12. X38
    X38
    Between the KY, lubed balls and ribs, this thread is so borderline. :D
  13. Dedsoto
    Dedsoto
    from Australia
    I went out with a girl who was borderline, all she could do was **** and fight
  14. BJR
    BJR
    Which was she better at?:p
    big duece likes this.
  15. CSPIDY
    CSPIDY
    Balls said the Queen!
  16. 41woodie
    41woodie
    Why not trim the opening just a little bit, after its on the ball and bolted up with the retainer it isn't going anywhere
  17. rusty valley
    rusty valley
    Use air pressure, they go rite on. easy peasy
    RICH B and alanp561 like this.
  18. theHIGHLANDER
    theHIGHLANDER
    Just the ***le of this one has "left turn" written all over it...:rolleyes:
  19. nobby
    nobby
  20. alanp561
    alanp561
    For those who are still interested, I finally got the rubber bushing on the wishbone ball. And yes, I did have the right bushing. I found my blowgun, lubed the ball and bushing with soapy water and tried pushing the bushing on while blowing 120 PSI air into the little hole on the end of the bushing. Only thing that accomplished was blowing soapy water all over me and my gl***es. Next, I tried @Glenn Thoreson 's approach. I lubed the bushing and ball again, grabbed the bushing and leaned all 245 pounds of me onto the bushing while twisting with both hands. I thought it was winning but, when I ran out of energy, the bushing was halfway on and not trying to pop off. After a short break, I grabbed it and grunted and, it popped right on. Tomorrow, I should have forearms like Popeye's ;).
    Tim, 427 sleeper, X38 and 3 others like this.
  21. Rickybop
    Rickybop
    That hurt just reading it.
    '29 Gizmo, kadillackid and alanp561 like this.
  22. X38
    X38
    That’s good. And lucky it only has one ball.;):D
    427 sleeper, kadillackid and alanp561 like this.
